is this little weird function of “proxy click” possible in verge?
Home Forums General Questions is this little weird function of “proxy click” possible in verge?
  • #71181
    visualizer
    Is it possible to give a proxy click in verge?
    I mean,
    Case 1 –
    the scene has objects A, B & C. All three has different animations in scene.
    Can I assign a click on A as a as a parallel or a proxy click to B? & also to C as well ?
    Note – I don’t want to assign clicking of A to start animation of B & C
    Case 2 –
    Scene has object A & there is something in parent doc. lets say B is html button
    Can I assign a click on A object to also assign a proxy click to B that is html button?
    Consider it is a kind of relay function or a proxy event.
    • This topic was modified 1 year, 1 month ago by visualizer.
    #71188
    What’s the difference? :scratch: In both cases B and C animations will start.
    Case 2 –
    document.getElementById('some_id').click();
    or if your element is in a parent document
    parent.document.getElementById('some_id').click();
    #71193
    visualizer
    hey KDV
    during discussion with the industrial team, we envisaged some areas where this type of proxy action is needed. Its a primary phase as of now.
    However something I wanted to just test before we discuss something with more deep & challenging comes ahead of us.
    When it comes to actual there might be more of such trick needed & I already have you in mind for the same.
    #71195
    :scratch: Ok, just think a little more…
    What is supposed to happen when B is clicked directly? What is supposed to happen after that so-called proxy click on B? As I see, in both cases exactly the same action will be performed. No? You see some other variants?
