Is there a way to rename tabs in the Puzzles Editor?
Home Forums General Questions Is there a way to rename tabs in the Puzzles Editor?
  • #40352
    psedlacek
    I often will make a tab and then wish to rename it, not sure how. Is it possible?
    #40353
    johngrigni
    You could try editing the visual_logic.xml file, but make a backup of the file first. Open it in a plain text editor, search for the name of your tab and change it. Then open it in the app manager and see if it worked.
    #40368
    psedlacek
    That worked great actually, thank you! Still would be nice to have this option in the interface.
    #40370
    johngrigni
    I should have mentioned this, and if anyone else uses this method:
    Make sure you’re changing the right thing and not something else with the same name, like a variable or an object. It will be an attribute inside a ‘tab’ tag:
    <tab name=”yourTabName” type=”….. >
    Don’t mess with anything but yourTabName, and leave it in quotes.
    Just remember to keep a backup in case you screw up the file (or you could just copy the last saved version in the v3d_app_data/puzzles_backup folder to your apps main directory and remove the timestamp from the filename).
    #59929
    As of Verge3D 4.3, you can rename tabs by double-clicking on their names. :good:
