Is it possible to use value sliders with no code?
Home Forums General Questions Is it possible to use value sliders with no code?
  • #76708
    domjasper
    Hello all,
    I have built my project in webflow, and added a value slider.
    See: https://webflow.com/made-in-webflow/website/Webflow-Range-Sliders
    Is it possible to use this slider to speed up and slow down an animation? Do I need to code or is it possible to use no code puzzles?
    #76709
    You can get the values of the sliders using the HTML Get Prop Value and the slider HTML ID.
    You can then assign it to a variable or do as need to via puzzles.
    #76713
    domjasper
    Awesome! Thank you very much xeon, I will give it a try. :good:
