Is it possible to move camera with mouse cursor?
Home Forums General Questions Is it possible to move camera with mouse cursor?
  • #56212
    mashud008
    Is it possible to move the 3D space with the mouse cursor? That is, when the mouse cursor is moved to the right, the camera will move to the right and when the mouse cursor is moved to the left, it will move to the left. As seen in three.js web interactive sites
    #56221
    It’s possible and it’s named “panning”. But the camera moves in the opposite direction so it looks like the object is moving on the screen.
    #56367
    mashud008
    Watch this video to see the 3D objects inside move when you move the mouse. That is, the 3D object is moving when the mouse is over. How to make it
    #56409
    Yes…you can. Here is an example: https://webgl.r66dapps.com/escapev1/. Go to the menu and switch the camera mode. You can see it in action.
    the following is java script code needed
    app.controls.rotateSpeed=-1;
    app.controls.rotateSpeedTouch= -1;
    Change from -1 to 1 depending on the direction needed.
    #56463
