is any way to move camera with enableDamping?
Home Forums Puzzles is any way to move camera with enableDamping?
  • #29667
    lee20
    Hi:
    Is any way have the same camera movement done in 3d max like this sample?
    https://cdn.soft8soft.com/demo/examples/index.html#misc_controls_map
    Any way can achieve the same effect? “enableDamping” in puzzle?
    Thank you.
    #30063
    Yep, you can achieve that with basic JavaScript scripting. Open the example code by clicking on the right bottom button and copy-paste to your own 3D app. See here for more info.
    X | FB | LinkedIn
    #30372
    web
    I would also be interested into using that feature, but couldnt get it work.
    Do you need to call app.controls.update() all the time via a whenMoved puzzle?
    #30395
    The app.controls.update(elapsed) executed automatically each frame in the App.js module. Check out the sources in your Verge3D distro (in the src/extras directory).
    X | FB | LinkedIn
    #30398
    web
    Okay, but why can’t I just use:
    function runCode(app) {
    app.controls.enableDamping = true;
    app.controls.dampingFactor = 0.05;
    Or does the damping simply not work in a puzzle based app? Do you need to go all the way and used the pure javascript method?
    #30404
    According to the example, you need to use MapControls class which is exported from the jsm/controls/OrbitControls.js file (this is not the same OrbitControls we use in the engine!). Check out the following code for more info.
    X | FB | LinkedIn
    #30413
    web
    Okay, will look into it. For the future I think it would be really cool if you could implement this option as a puzzle.
    #31220
    lee20
    Hi:
    How can I incorporate the MapControls class in my project? I am using puzzle interface. The example in the library are using the hand coding script that calling the different orbit controller.
    How can archive it by using the puzzle? I alway think the puzzle is the replacement for the hand coding. I have three.js experience. do u have example that how to manipulate script section v3d coding and puzzle working together. Like orbit map control function, how can I call in different orbit controller but not using the v3d default one.
    Thank yo every much.
    #31223
    Please check out this page: https://www.soft8soft.com/docs/manual/en/introduction/Using-JavaScript.html
