Invisible “Hit/click box’s” without shader call?
Home Forums Puzzles Invisible “Hit/click box’s” without shader call?
  • #28700
    GLiFTeK
    When making invisible objects as “hitboxes” (areas for registering clicks/drags) is there a more efficient way to have them available to Verge, WITHOUT having to have their material call a transparency node?
    I have been using transparency with a mix shader node with factor of 0.0001.
    one technique to lower shader calls would be to give every hit box object the same said transparency material.
    Am I right with that? Is there a different method that wouldn’t need to even do this? One that wouldn’t waste a material shader call on something that’s never seen?
    Thanks!
    #28715
    Unfortunaly there’s no other method for now. But you can use a Alpha Clip type for blend of materials to get less video card load.
