Home › Forums › WebGL & WebXR Troubleshooting › Introducing WebGL troubleshooting topic
Tagged: chrome, display issues, troubleshooting, webgl, windows
- This topic has 32 replies, 9 voices, and was last updated 2 years, 12 months ago by
danielbruno.
2018-08-17 at 10:44 am #6576
Alexander Kovelenov
StaffAlthough the adoption rate of the WebGL technology is close to 100%, some users can still experience issues with their browsers or hardware.
Please read the following guide for possible solutions. If nothing helped, feel free to report your issue in this forum topic.
It would help a lot if you provide the following information in your forum post:
- Browser name and version
- OS name and version
- Your graphics hardware specs for desktops or the model of your mobile device
2018-11-22 at 3:01 pm #9072illussimo
CustomerHello Alexander,
Unfortunately, Apple both in both MacOS and iOS has only limited support for WebGL. It will only load max 8 textures so parts of the scene might not show up.
Apple support might change in the future but for now, we will have to think of workarounds. Unfortunately, it hampers getting visually appealing 3D content to Apple users.
It is nothing Verge3D can do about. Apple might change its mind. We will just have to be patient…
Simone
2018-11-22 at 3:37 pm #9082Alexander Kovelenov
Staff2018-11-22 at 4:23 pm #9091illussimo
CustomerThanks for the link!
Simone
2019-01-10 at 8:35 am #10479vincent
CustomerHello,
In my case, my scene in Verge3D doesn’t work on Apple device.
Ipad Air
Iphone 5s
Iphone 7+
Iphone Xr (with chrome V 71.0.357889)Some objects are missing, other are present but they don’t have their textures images. The light is down too… the scene is very long to upload.
Would you give me more explications about number of texture… we can only work with 8 objects and textures isn’t it ?
Other question : texture is a simple color ?2019-01-10 at 9:05 am #10480vincent
CustomerAfter some request on web, Metal is the new engine 3D !
2019-01-10 at 1:29 pm #10499Yuri Kovelenov
StaffHi,
You can visit the webgl report page from your iOS devices to see what maximum limit they offer for textures (the parameter is called Max Texture Image Units).
Please note that Verge3D reserves a texture unit per each lamp on the scene for internal rendering purposes.2019-01-10 at 1:31 pm #10500Yuri Kovelenov
StaffAfter some request on web, Metal is the new engine 3D !
Yes, Apple deprecated OpenGL but not WebGL, fortunately.
2019-02-03 at 3:53 pm #10994iltech
ParticipantI am a teacher at a K-5 school. Our students have access to Lenovo N22 chromebooks. I have enabled webgl on their chrome browsers but we still receive the message that webgl is not enabled. I have also updated Chrome to it’s latest version, any ideas? See attached for Chromebook specs.
2019-02-04 at 7:02 am #11000Yuri Kovelenov
Staff2019-02-05 at 1:29 am #11025iltech
ParticipantGraphics Feature Status
Canvas: Hardware accelerated
Flash: Hardware accelerated
Flash Stage3D: Hardware accelerated
Flash Stage3D Baseline profile: Hardware accelerated
Compositing: Hardware accelerated
Multiple Raster Threads: Disabled
Native GpuMemoryBuffers: Hardware accelerated
Out-of-process Rasterization: Disabled
Hardware Protected Video Decode: Unavailable
Rasterization: Hardware accelerated
Skia Deferred Display List: Disabled
Skia Renderer: Disabled
Surface Control: Disabled
Surface Synchronization: Enabled
Video Decode: Hardware accelerated
Viz Service Display Compositor: Disabled
WebGL: Hardware accelerated
WebGL2: Hardware accelerated
Driver Bug Workarounds
clear_uniforms_before_first_program_use
count_all_in_varyings_packing
decode_encode_srgb_for_generatemipmap
disable_discard_framebuffer
msaa_is_slow
rely_on_implicit_sync_for_swap_buffers
scalarize_vec_and_mat_constructor_args
disabled_extension_GL_KHR_blend_equation_advanced
disabled_extension_GL_KHR_blend_equation_advanced_coherent
Problems Detected
Protected video decoding with swap chain is for Windows and Intel only
Disabled Features: protected_video_decode
Framebuffer discarding causes jumpy scrolling on Mali drivers: 301988
Applied Workarounds: disable_discard_framebuffer
Clear uniforms before first program use on all platforms: 124764, 349137
Applied Workarounds: clear_uniforms_before_first_program_use
Mesa drivers in ChromeOS handle varyings without static use incorrectly: 333885
Applied Workarounds: count_all_in_varyings_packing
Always rewrite vec/mat constructors to be consistent: 398694
Applied Workarounds: scalarize_vec_and_mat_constructor_args
On Intel GPUs MSAA performance is not acceptable for GPU rasterization: 527565
Applied Workarounds: msaa_is_slow
Disable KHR_blend_equation_advanced until cc shaders are updated: 661715
Applied Workarounds: disable(GL_KHR_blend_equation_advanced), disable(GL_KHR_blend_equation_advanced_coherent)
Decode and Encode before generateMipmap for srgb format textures on Chromeos Intel: 634519
Applied Workarounds: decode_encode_srgb_for_generatemipmap
Avoid waiting on a egl fence before pageflipping and rely on implicit sync.: 721463
Applied Workarounds: rely_on_implicit_sync_for_swap_buffers
Raster is using a single thread.
Disabled Features: multiple_raster_threads
Viz service display compositor is not enabled by default.
Disabled Features: viz_display_compositor
Skia renderer is not used by default.
Disabled Features: skia_renderer
Skia deferred display list is not used by default.
Disabled Features: skia_deferred_display_list
Version Information
Data exported 2019-02-05T01:28:23.598Z
Chrome version Chrome/71.0.3578.127
Operating system Linux 11151.113.0
Software rendering list URL https://chromium.googlesource.com/chromium/src/+/ab04191dbdc8146b84b76a6e91a762b88574eaa4/gpu/config/software_rendering_list.json
Driver bug list URL https://chromium.googlesource.com/chromium/src/+/ab04191dbdc8146b84b76a6e91a762b88574eaa4/gpu/config/gpu_driver_bug_list.json
ANGLE commit id f2ed299569c0
2D graphics backend Skia/71 7469a9341afab19271b8ef07af5c16a0f2c4ccc1-
Command Line /opt/google/chrome/chrome –ppapi-flash-path=/opt/google/chrome/pepper/libpepflashplayer.so –ppapi-flash-version=32.0.0.101 –ui-prioritize-in-gpu-process –use-gl=egl –enable-native-gpu-memory-buffers –gpu-sandbox-failures-fatal=yes –enable-logging –log-level=1 –use-cras –enable-wayland-server –user-data-dir=/home/chronos –login-profile=user –has-chromeos-keyboard –guest-wallpaper-large=/usr/share/chromeos-assets/wallpaper/guest_large.jpg –guest-wallpaper-small=/usr/share/chromeos-assets/wallpaper/guest_small.jpg –child-wallpaper-large=/usr/share/chromeos-assets/wallpaper/child_large.jpg –child-wallpaper-small=/usr/share/chromeos-assets/wallpaper/child_small.jpg –default-wallpaper-large=/usr/share/chromeos-assets/wallpaper/default_large.jpg –default-wallpaper-small=/usr/share/chromeos-assets/wallpaper/default_small.jpg –enable-consumer-kiosk –arc-availability=officially-supported –enable-features=Crostini,ExperimentalCrostiniUI –enterprise-enrollment-initial-modulus=15 –enterprise-enrollment-modulus-limit=19 –login-user=abraddock@inlandlakes.org –login-profile=ede9f7d30ed335771659f9a10cc466c2f9ff30bf –flag-switches-begin –enable-webgl-draft-extensions –flag-switches-end –vmodule=*arc/*=1,nss_cert_database_chromeos=1,*/assistant/*=1,*chromeos/login/*=1,auto_enrollment_controller=1,*/ui/ozone/*=1,*/ui/display/manager/chromeos/*=1,*night_light*=1,update_engine=1,component_updater_service=1,power_button_observer=2,webui_login_view=2,lock_state_controller=2,webui_screen_locker=2,screen_locker=2 –enable-features=Crostini,ExperimentalCrostiniUI
Driver Information
Initialization time 132
In-process GPU false
Passthrough Command Decoder false
Sandboxed true
GPU0 VENDOR = 0x8086 [Intel Open Source Technology Center], DEVICE= 0x22b1 [Mesa DRI Intel(R) HD Graphics 400 (Braswell) ] *ACTIVE*
Optimus false
AMD switchable false
Driver vendor Mesa
Driver version 18.2.0
Driver date
GPU CUDA compute capability major version 0
Pixel shader version 3.10
Vertex shader version 3.10
Max. MSAA samples 8
Machine model name
Machine model version
GL_VENDOR Intel Open Source Technology Center
GL_RENDERER Mesa DRI Intel(R) HD Graphics 400 (Braswell)
GL_VERSION OpenGL ES 3.1 Mesa 18.2.0-devel (git-0f959215c3)
GL_EXTENSIONS GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_APPLE_texture_max_level GL_EXT_blend_func_extended GL_EXT_blend_minmax GL_EXT_buffer_storage GL_EXT_clip_cull_distance GL_EXT_color_buffer_float GL_EXT_compressed_ETC1_RGB8_sub_texture GL_EXT_copy_image GL_EXT_discard_framebuffer GL_EXT_disjoint_timer_query GL_EXT_draw_buffers GL_EXT_draw_buffers_indexed GL_EXT_draw_elements_base_vertex GL_EXT_frag_depth GL_EXT_geometry_point_size GL_EXT_geometry_shader GL_EXT_gpu_shader5 GL_EXT_map_buffer_range GL_EXT_multi_draw_arrays GL_EXT_occlusion_query_boolean GL_EXT_polygon_offset_clamp GL_EXT_primitive_bounding_box GL_EXT_read_format_bgra GL_EXT_robustness GL_EXT_separate_shader_objects GL_EXT_shader_framebuffer_fetch_non_coherent GL_EXT_shader_integer_mix GL_EXT_shader_io_blocks GL_EXT_shader_samples_identical GL_EXT_tessellation_point_size GL_EXT_tessellation_shader GL_EXT_texture_border_clamp GL_EXT_texture_buffer GL_EXT_texture_compression_dxt1 GL_EXT_texture_cube_map_array GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_texture_norm16 GL_EXT_texture_rg GL_EXT_texture_sRGB_decode GL_EXT_texture_type_2_10_10_10_REV GL_EXT_unpack_subimage GL_INTEL_performance_query GL_KHR_blend_equation_advanced GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_MESA_framebuffer_flip_y GL_MESA_shader_integer_functions GL_NV_draw_buffers GL_NV_fbo_color_attachments GL_NV_image_formats GL_NV_read_buffer GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_compressed_ETC1_RGB8_texture GL_OES_copy_image GL_OES_depth24 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_draw_buffers_indexed GL_OES_draw_elements_base_vertex GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_geometry_point_size GL_OES_geometry_shader GL_OES_get_program_binary GL_OES_gpu_shader5 GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_primitive_bounding_box GL_OES_required_internalformat GL_OES_rgb8_rgba8 GL_OES_sample_shading GL_OES_sample_variables GL_OES_shader_image_atomic GL_OES_shader_io_blocks GL_OES_shader_multisample_interpolation GL_OES_standard_derivatives GL_OES_stencil8 GL_OES_surfaceless_context GL_OES_tessellation_point_size GL_OES_tessellation_shader GL_OES_texture_3D GL_OES_texture_border_clamp GL_OES_texture_buffer GL_OES_texture_cube_map_array GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_texture_stencil8 GL_OES_texture_storage_multisample_2d_array GL_OES_vertex_array_object GL_OES_vertex_half_float GL_OES_viewport_array
Disabled Extensions GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent
Disabled WebGL Extensions
Window system binding vendor Mesa Project
Window system binding version 1.4 (DRI2)
Window system binding extensions EGL_ANDROID_blob_cache EGL_EXT_create_context_robustness EGL_EXT_image_dma_buf_import EGL_EXT_image_dma_buf_import_modifiers EGL_KHR_config_attribs EGL_KHR_create_context EGL_KHR_create_context_no_error EGL_KHR_fence_sync EGL_KHR_get_all_proc_addresses EGL_KHR_gl_colorspace EGL_KHR_gl_renderbuffer_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_3D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_image_base EGL_KHR_no_config_context EGL_KHR_reusable_sync EGL_KHR_surfaceless_context EGL_EXT_pixel_format_float EGL_KHR_wait_sync EGL_MESA_configless_context EGL_MESA_drm_image EGL_MESA_image_dma_buf_export
Direct rendering Yes
Reset notification strategy 0x8252
GPU process crash count 0
Compositor Information
Tile Update Mode One-copy
Partial Raster Enabled
GpuMemoryBuffers Status
R_8 CAMERA_AND_CPU_READ_WRITE, SCANOUT_CPU_READ_WRITE, GPU_READ_CPU_READ_WRITE, GPU_READ_CPU_READ_WRITE_PERSISTENT
R_16 Software only
RG_88 SCANOUT_CPU_READ_WRITE, GPU_READ_CPU_READ_WRITE, GPU_READ_CPU_READ_WRITE_PERSISTENT
BGR_565 GPU_READ
RGBA_4444 Software only
RGBX_8888 GPU_READ, SCANOUT, SCANOUT_CPU_READ_WRITE
RGBA_8888 GPU_READ, SCANOUT, SCANOUT_CPU_READ_WRITE
BGRX_8888 GPU_READ, SCANOUT, SCANOUT_CPU_READ_WRITE
BGRX_1010102 Software only
RGBX_1010102 SCANOUT_CPU_READ_WRITE
BGRA_8888 GPU_READ, SCANOUT, SCANOUT_CPU_READ_WRITE, GPU_READ_CPU_READ_WRITE, GPU_READ_CPU_READ_WRITE_PERSISTENT
RGBA_F16 Software only
YVU_420 GPU_READ
YUV_420_BIPLANAR SCANOUT_CAMERA_READ_WRITE, SCANOUT_CPU_READ_WRITE, GPU_READ_CPU_READ_WRITE, GPU_READ_CPU_READ_WRITE_PERSISTENT
UYVY_422 Software only
Display(s) Information
Info Display[2785062953156608] bounds=[0,0 1366×768], workarea=[0,0 1366×712], scale=1, internal.
Color space information {primaries:INVALID, transfer:INVALID, matrix:INVALID, range:INVALID}
Bits per color component 8
Bits per pixel 24
Video Acceleration Information
Decode h264 baseline up to 4096×4096 pixels
Decode h264 main up to 4096×4096 pixels
Decode h264 high up to 4096×4096 pixels
Decode vp8 up to 4096×4096 pixels
Decode vp9 profile0 up to 4096×4096 pixels
Encode h264 baseline up to 4096×4096 pixels and/or 30.000 fps
Encode h264 main up to 4096×4096 pixels and/or 30.000 fps
Encode h264 high up to 4096×4096 pixels and/or 30.000 fps
Log Messages
[2985:2992:0204/202706.978897:VERBOSE1:drm_device_manager.cc(58)] : Primary DRM device added: /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[2985:2992:0204/202708.416972:VERBOSE1:drm_device_manager.cc(53)] : Could not initialize DRM device for /sys/devices/platform/vgem/drm/card1
[2985:2992:0204/202709.041249:ERROR:drm_gpu_display_manager.cc(209)] : There is no display with ID 2785062953156608
[2985:2992:0204/202710.327120:VERBOSE1:drm_display.cc(104)] : DRM configuring: device=/sys/devices/pci0000:00/0000:00:02.0/drm/card0 crtc=26 connector=47 origin=0,0 size=1366×7682019-02-05 at 7:14 am #11026Yuri Kovelenov
StaffWebGL: Hardware accelerated
WebGL2: Hardware acceleratedLooks like WebGL is available. Does this website show a green message and a rotating cube? https://get.webgl.org/
If it does, how about Verge3D demos in the gallery?2019-02-05 at 8:39 am #11027vincent
CustomerIt will only load max 8 textures so parts of the scene might not show up.
I fixed my problem on Apple devices. For me it’s a very important limitation, all the designers will be to know this rules to synchronise their work on multiple mobile device (iOs and android)
Thanks you very much Simo3Dw.
2019-02-05 at 2:47 pm #11044iltech
ParticipantThis is what we get when we try any website with WebGl. The second screenshot is https://get.webgl.org/
2019-02-05 at 4:08 pm #11051Yuri Kovelenov
StaffOkay, can you try the following: navigate to chrome://flags/ and enable Override software rendering list.
If it doesn’t help, I recommend to file a bug report to Chrome bug tracker:
https://bugs.chromium.org/p/chromium/issues/list?can=2&q=component%3ABlink%3EWebGL+&colspec=ID+Pri+M+Stars+ReleaseBlock+Component+Status+Owner+Summary+OS+Modified&x=m&y=releaseblock&cells=ids
You’ll need a Google account to do this. -
