Interior scene (EEVEE)
Home › Forums › Graphics / Blender › Interior scene (EEVEE)
Viewing 14 posts - 1 through 14 (of 14 total)
  • #18443
    Ozbend
    Has anyone tried to make an interior scene? The problem is unsupported lighting options (Area Light, Light Probes etc). I get a nightmare result. I’m trying to understand what can I do to get an acceptable result.
    #18446
    Ozbend
    Some update. Worked on shaders. But still the same problem – lighting. The image is too flat.
    #18451
    The ony way to get a good result is to bake all lighting to a textues. Shadow, ambient, reflections and combine them somehow in shaders. Like in this demo.
    #18454
    Ozbend
    From some forum “…currently there is no option to bake lighting to textures in Eevee, the options just exists in Cycles”.
    #18455
    I mean you need to bake all in Cicles.
    #18456
    Ozbend
    Oh, I get it. But you don’t think that instead of developing many different things (resizing an object, etc.) you should solve a more important problem like lighting?
    #18461
    Ozbend
    How can i use Cycles, if isn’t supported?
    #18463
    All things important and will be supported some day.
    You can bake texture using Cicles then switch to EEVEE and connect all textures there.
    #18488
    Ozbend
    I tried this way. Too complicated and long process. I want to build a scene, press sneak peek and see the result. All that is needed is to make support for all lighting options. Sorry for such answer.
    #18492
    All things for realtime rendering is complicated to develop, it’s a pay for realtime. I don’t think that only light support will solve your problems. As I can see you also use AO, SSR or cubemap lightprobe and irradence map. Even if we support all this feature all of them will slow down the application. So bayking is the best chice for performance.
    #19167
    Avier3D
    Hi Ozbend,
    When you say “I tried this way. Too complicated and long process. I want to build a scene, press sneak peek and see the result”, I think you are not aware you are asking for the holly grail that giants from Nvidia to Intel to Apple to many other software companies have been trying to solve for decades.
    WebGL is just one more flavour of OpenGL. And although nowadays it is kind of possible (Eevee, UE4 and others), they still belong to very complicated systems and expensive hardware.
    Which is a quite different from the WebGL scenario, which is “convenient”, ergo, browsers in smartphones, tablets, desktops, or even cheap NUC’s attached to giant touch screens (I did a test, works great!).
    You are asking for a magical think at this stage.
    There’s two options:
    -Fund Soft8Soft with enough capital to hire all the workforce to design such brilliant piece of software, yes please pretty please :)
    -Or, be a 3D artist that knows production pipeline and the “Too complicated and long process” you mention is just part of your skills. I do this as a week job and earn an entire living, married with children. If I can, you can too :)
    #19168
    @Avier3D well said! :good:
    #19439
    chidu
    The demo example done is using combination of Blender and Verge3D?
    Chidanand.G
    #19451
    I recall the topic starter is a Max user.
