interface for configurator
Home Forums General Questions interface for configurator
  • #31357
    farzinkhodadadi
    Hello, im trying to make a configurator in verge3D and, i am using some online services to make the interface for that configurator. just need to know how to connect these two.
    because here in your website you explain how to make interface but by writing codes. as im not a programmer and i cant write the code. im using some online services like justinmind.com as tool for UI design. not coding. but need to know how to make it work in made configurator in verge 3D.
    thank you in advance.
    #31362
    please take a look at this tutorial:
    #31398
    farzinkhodadadi
    thanks. but i already checked it. its just for a small sample. that has been writed. but i need to connect my created interface using justinmind.com to be function in verge3D. but now when i save the file inside the folder of my created configurator appplication in verge. and after i open the open it as html saved in application folder is just showing me my html page. and it is not showing the 3D shape on the back.
    #31425
    Please make sure that you specified a correct path for your iframe element.
