Home › Forums › Bug Reports and Feature Requests › Installation Errors ( OS X )
- This topic has 12 replies, 3 voices, and was last updated 5 years, 8 months ago by
rhenriques.
2019-07-16 at 9:35 pm #17063
digitalelements
ParticipantHi There,
Is anyone else having errors when trying to enable Verge
in Blender RC1 on Mac OS ? ( 10.14.5 )I’ve included the text from the console for clues.
Thank you,
Chris
2019-07-17 at 7:05 am #17068Yuri Kovelenov
Staff2019-07-17 at 10:31 am #17082digitalelements
ParticipantSorry Yuri ..I had thought I had attached a text file.
Pasting the console text below. and thank you!bpy.data.window_managers[“WinMan”].addon_search = “ver”
Traceback (most recent call last):
File “/Applications/Blender.app/Contents/Resources/2.80/scripts/modules/addon_utils.py”, line 384, in enable
mod.register()
File “/Users/chrisryan/Documents/Blender Files/AddOns/2.8/verge3d/addons/verge3d/__init__.py”, line 218, in register
from . import custom_props, custom_ui
File “/Users/chrisryan/Documents/Blender Files/AddOns/2.8/verge3d/addons/verge3d/custom_props.py”, line 20, in <module>
from . import utils
File “/Users/chrisryan/Documents/Blender Files/AddOns/2.8/verge3d/addons/verge3d/utils.py”, line 19, in <module>
import numpy as np
File “/Applications/Blender.app/Contents/Resources/2.80/python/lib/python3.7/site-packages/numpy/__init__.py”, line 142, in <module>
from . import add_newdocs
File “/Applications/Blender.app/Contents/Resources/2.80/python/lib/python3.7/site-packages/numpy/add_newdocs.py”, line 13, in <module>
from numpy.lib import add_newdoc
File “/Applications/Blender.app/Contents/Resources/2.80/python/lib/python3.7/site-packages/numpy/lib/__init__.py”, line 8, in <module>
from .type_check import *
File “/Applications/Blender.app/Contents/Resources/2.80/python/lib/python3.7/site-packages/numpy/lib/type_check.py”, line 11, in <module>
import numpy.core.numeric as _nx
File “/Applications/Blender.app/Contents/Resources/2.80/python/lib/python3.7/site-packages/numpy/core/__init__.py”, line 35, in <module>
from . import _internal # for freeze programs
File “/Applications/Blender.app/Contents/Resources/2.80/python/lib/python3.7/site-packages/numpy/core/_internal.py”, line 15, in <module>
import ctypes
File “/Applications/Blender.app/Contents/Resources/2.80/python/lib/python3.7/ctypes/__init__.py”, line 543, in <module>
_reset_cache()
File “/Applications/Blender.app/Contents/Resources/2.80/python/lib/python3.7/ctypes/__init__.py”, line 273, in _reset_cache
CFUNCTYPE(c_int)(lambda: None)
MemoryError2019-07-17 at 1:15 pm #17086Yuri Kovelenov
Staff2019-07-17 at 1:51 pm #17090digitalelements
ParticipantI’ve been using the same path to scripts for many weeks.
I always unpack and place the payload in the same location.
It wasn’t until RC1 and the latest Verge version that I encountered the
Errors.2019-07-17 at 2:14 pm #17091Yuri Kovelenov
StaffIt seems to be Blender’s bug which Verge3D addon revealed. Found a possible workaround here
https://github.com/powerline/powerline/issues/1947#issuecomment-431784358Try editing the file
and commenting out the line:
so it looks as follows:
#CFUNCTYPE(c_int)(lambda: None)
2019-07-17 at 2:17 pm #17093Yuri Kovelenov
Stafffresh update:
https://www.crowd-render.com/single-post/2019/07/15/Work-Around-for-addons-not-working-on-MacOS-Blender-280-RC1and
https://developer.blender.org/T66986
Looks like this issue is already fixed. Try downloading the newest Blender 2.80 RC1 build.
2019-07-17 at 2:30 pm #17095digitalelements
ParticipantI’ve been using that build. It is what brought my other AddOns back.
I tried Commenting out the line you had suggested but, no success.I appreciate the help as I know that Mac OS users are few and far between : )
2019-07-17 at 2:57 pm #17096Yuri Kovelenov
Staff2019-07-17 at 2:58 pm #17097digitalelements
Participantindeed there re errors
>>> import ctypes
File “<blender_console>”, line 1, in <module>
_reset_cache()
MemoryError2019-07-17 at 3:11 pm #17098Yuri Kovelenov
StaffWell, I guess your Blender version does not contain the fix from https://developer.blender.org/T66986
Blender devs are going to release RC2 later this week. Once they do this, you might want to update and see if the issue is gone.
2019-07-17 at 3:13 pm #17099digitalelements
ParticipantThank you for your time Yuri …
I will wait for the release of RC22019-07-19 at 3:25 am #17121rhenriques
CustomerHi digitalelements, I had the same problem. The trick, for now, is to disable SIP and Gatekeeper. That way you will be able to enable Verge3D add on.
