Input fields
Home Forums General Questions Input fields
  • #32218
    parsec
    Hi new over here wondering if it is possible in verge to integrate text input fields and connect with a google Sheets database.
    Also would be possible to have a plane displaying a JS mini game in 3d, and have verge capture results to Triger something on the scene?
    #32228
    sure you can use HTML-based UI as well as JavaScript in your app. Sometimes it is possible to do everything with the Puzzles alone.
    that would require 3D CSS transformations for the iframe element (in which you can load the game), synchronized with a 3D plane.
    this is quite advanced topic – you look at this guide for example: http://learningthreejs.com/blog/2013/04/30/closing-the-gap-between-html-and-webgl/
