Input color to change a Verge3D material color
Home Forums Programming Input color to change a Verge3D material color
  • #15866
    yasse
    Hello :)
    Hope you doing great, I’m wondering if there any possibility to link a color input to change a Verge3D Material base color like in fine_wood in the Material pack.
    <input type=”color” id=”head” name=”head”
    value=”#e66465″>
    <label for=”head”>Head</label>
    Is there any way to do this, please ? or someone faced this before?
    #15874
    Yes, you can retrieve the value of a color input element using the get attribute / value puzzle. It will output a text value, which you then need to convert to R, G, B numeric values (with Number puzzles or JavaScript) in order to supply them to the material using set color puzzle.
