Home › Forums › General Questions › Initialisation/Preloading all Assets, incl. hidden
- This topic has 7 replies, 3 voices, and was last updated 4 months, 3 weeks ago by
tomtm.
2024-10-31 at 12:39 pm #78351
tomtm
CustomerHi,
what is the best way to pre load all assets? I know, there are some other posts,
but no of this code snippets did push everything in the memory before the app starts.Usually I place everything in the camera view and make things all unhidden and hide again.
But this might be a little “old” school?
Is there a code which would force all shaders to be compiled and objects
be loaded in the memory before the app starts?Greets Tom
2024-10-31 at 2:19 pm #78355kdv
Participantwhich would force all shaders to be compiled
all material shaders are already compiled on loading.
and objects be loaded in the memory
app.scene.traverse(function(obj) { if (obj.isMesh) { if (obj.material.isMeshNodeMaterial) { for (let name in obj.material.nodeTextures) { app.renderer.initTexture(obj.material.nodeTextures[name]); } } app.renderer.updateGeometry(obj); } });
2024-10-31 at 9:40 pm #78381tomtm
CustomerHi Kdv
Do you put this script in the very beginning of the puzzle?
I still have the situation, that some actions have some frame drops the first time they run.
After playing the animation the second time, it is fine.2024-10-31 at 9:46 pm #78382kdv
Participantwithout your files it’s hard to find out what is the best way to get rid of lags
sometimes that code works fine, sometimes it’s not good enough.
2024-11-01 at 2:43 am #78383tomtm
CustomerHi
unfortunately due to a NDA I can‘t share the scene.
Maybe I have to many calls when I start an animation, but this wouldn‘t explain, why it‘s working after I called it
one time.Thanks for the script and help!
Tom2024-11-01 at 2:46 am #78384kdv
ParticipantI can‘t share the scene.
then you’re on your own
2024-11-01 at 2:57 am #78385c4cc
Might I suggest distorting/messing up the mesh, changing the colors of materials/shaders/procedural effects, etc, to change its physical appearance WHILE RETAINING the original line/vertices count and shader/procedural effect methods the same? That way, the principles of the answer can be derived while anonymity retained.
2024-11-05 at 9:33 am #78448tomtm
CustomerI hope I can post a sample scene soon.
I am really curious how to make initialisation better, especially if you enter VR, there are likely more difficulties due to the nature of weaker hardware. -
