Influence of HTML binded element when dragging Objects
Home Forums Programming Influence of HTML binded element when dragging Objects
  • #66569
    David Duperron
    Hi!
    I’ve just created some custom binded HTML elements (div) to display some information about some 3D objects in my scene. Everything works fine until I want to drag/move some other objects in my scene:
    when the mouses passes over one of these HTML binded elements, the dragged objects jumps in the upper leftcorner of the 3D view (like if I had moved my pointer to this upper left corner).
    Is there some CSS property or tweak to be added somewhere to avoid that?
    Thanks for the help!
    Regards
    David
    #66572
    Disable “pointer-events” for them.
    #66574
    David Duperron
    perfect! Thanks!
