Inaccurate raycast on camera rotation?
Home › Forums › Programming › Inaccurate raycast on camera rotation?
  • #40568
    elie520
    Hello,
    Context:
    I wrote some javascript to have the following behaviour on my blender scene:
    -when a user clicks on an object, it places a dot at the clicking point, and
    -when the view changes, the dot moves in order to follow the clicked point in the scene.
    I do this in two steps:
    1- On click, I retrieve the click location in the 3D scene using (clientX, clientY) from the click event, and verge’s raycasting method.
    2- On camera movement, I compute the position of the 3D location on the screen and move the point accordingly.
    My problem:
    I attached the results I get on two examples.
    On both parts of the clip, I start by translating the camera and then I rotate it. You can clearly see that the translating part works very smoothly, and the rotating part kind of flickers.
    Do you have any idea to help me? Thanks!
    #40581
    This kind of “lagging” usually happens when the code that uses the position/rotation of a camera (or any other object) is executed before those transforms are automatically updated on the current frame. As a result it uses the old values and therefore has 1 frame lag.
    It’s difficult to say without the actual code, but if you use the camera transforms in your calculations then updating the camera’s world matrix just before obtaining its position/rotation may help:
    camera.updateMatrixWorld();
    #40670
    elie520
    Thank you for your answer!
    As soon as I have some time I’ll look into your idea, and eventually share the cleaned code if I still need help. In any case, I’ll get back to you.
    Cheers
