Import Gif animations
Home Forums Graphics / Blender Import Gif animations
  • #71962
    felix
    HI. I wanted to know if it is possible to enable gif animations in verge3D. I created the separate gif frames as transparent pngs, and imported them into Blender. In blender it works and allows me to export as .gltf. When I open the Verge, I see a still frame – nothing is moving. Is this impossible or was I just trying to activate something? Thank you
    #71967
    You need to convert gif animation to regular video file, preferably mp4 and then use the video texture puzzle to assign and start such video.
    #71968
    Or create a sprite sheet
    #71997
    felix
    Ok, but how about transparency?
    Thank you
    #72002
    Sprite sheets support transparency
    #72014
    Videos can also be transparent, but there are some limitations. Thus, sprite animation might be a better solution. :good:
    #72019
    felix
    Thank You!!! Will try :yes:
