Implementing Verge3D with Angular
Home Forums General Questions Implementing Verge3D with Angular
  • #23470
    jstubb
    Hello,
    I am currently attempting to build a web application that implements visual components with the use of Verge3D and allows for interaction with the visual model via Angular. My goal is to link puzzles functionality with this framework but I am having trouble finding a method of properly installing Verge3D since most libraries for this framework are installed using npm. I’ve imported it using:
    import * as v3d from '"path"';
    But because it does not have any associated Typescript definition file I am unsure this is working as intended at the moment.
    Is there a known way to better go about this process? Any feedback would be appreciated.
    #23504
    Sorry we haven’t tried integrating Verge3d with Angular yet :unsure: May be someone from the community can share their experience?
    #23515
    jstubb
    The javascript files for a Verge3d application (as well as any other custom javascript files) can be imported by following this guide:
    Using external JS files in Angular
    However I have yet to fully test this application so some functionality may be limited. I will update this post at a later date.
    #23524
    Great! Let us know how it goes!
    #61254
    Starting from 4.3 you can import Verge3D directly by using NPM.
    X | FB | LinkedIn
