Home › Forums › General Questions › I’m still struggle in it… Webflow or WordPress??
- This topic has 7 replies, 4 voices, and was last updated 2 years, 7 months ago by
Crunch.
2023-11-09 at 2:19 am #68305
gee_lau2000
CustomerMay I have any suggestion from you guys?…
1. Can I still use Webflow as a tool for HTML Base UI? (Like the example of Swiss Knife)
2. If not, can WordPress’s Elementor be used as an alternative?
I have two main goals. The first is to create my own projects (Verge App) and publish them on the internet as my profilo. The second is to use a configurator for online shopping.
I know that they are differecne workflow and different tools are needed to achieve these two goals. Can you give me some specific recommendations, such as whether I need to purchase Webflow, WordPress, WooCommerce, etc.?
I greatly appreciate everyone’s help! I’ve been thinking about these questions for a long time and couldn’t find a solution.
2023-11-09 at 4:38 am #68307
xeonCustomerHi there,
You can use WebFlow, WordPress, or anything you want including hand-coding it.
So given that you can use anything you want you have to decide what’s best for you to create an online shopping experience and what tools, security, and experience you want to provide your customers.On the other hand you say this is a portfolio site. Are you going to create the designs or are you going to start from a template? Which company offers you the best deal. Honestly, they will all work. Find one that has a good community of users that will offer you the most help. Since you seem like you may be new to this…that would be the biggest advantage to any of the platforms you are looking at. V3D is just an HTML canvas that can be implemented on any web service so you aren’t restricted due to V3D.
The reason you can’t find a solution is the solution is always specific to the person. There is no one answer that is right for everyone. As long as you are willing to dive in, ask questions, and learn you will be successful. If you have friends that know how to use one platform over the other…use that … get their help and if you decide to switch later…switch. It’s all about learning anyway.
If you are going to sell products …then you may want to select the one that has the best merchant rates or integration. You may also want to consider your future customers where will they be coming from and will the experience be something they are familiar with.
My advise…jump in take one for a test drive see how it goes….if you don’t like it try the next one! Good luck.
Tutorials - https://www.xeons3dlab.com2023-11-09 at 5:09 am #68310gee_lau2000
CustomerHello Xeon,
Thank you very much for giving me advises and suggestion all the time!!
Yes, I’m an newbie and… actully there is no one around me doing same stuffs as what i’m doing…I’ll follow what you mentioned!Try it first, don’t think too much!
Thank’s again!!
Gee
2023-11-10 at 12:09 am #68331bigmike814
ParticipantYou should code it yourself. Elementor is as much of a learning curve as learning HTML and CSS.
I’d recommend checking out a bootstrap tutorial on YouTube. There’s also free templates and the components are free.
Also download visual studio code to edit in. 90% of the tutorials online will use it so it’s easy to follow along.
The only reason they recommend web flow is because it allows you to insert your own html (so you can insert an iframe). I wouldn’t even do that. Just code it on the html file they give you. If you need the index.html file, just change the name when you upload it to c-panel.
If you can learn the puzzles, HTML is easy AF.
3d Configurator | https://mc2sheds.com/builder
Site | https://mc2cpq.com
2023-11-14 at 8:18 am #68527gee_lau2000
CustomerHi bigmike814,
Thank you very much fo your suggestions!
May I ask one more things about is it possible upload the Verge3d app inculded all files to any web hosting like bluehost etc after design the UI with Webflow?
Thanks!
2023-11-14 at 2:23 pm #68545bigmike814
ParticipantYeah. You can upload it to C-panel.
It’s really just a matter of having an index page and dropping it into the public folder. Super easy.
2023-11-15 at 1:29 am #68564gee_lau2000
CustomerThanks so much!!!!
2023-11-22 at 4:43 am #68726
CrunchCustomerI’ve tried most everything in regards to solutions for html ui design… ended up where I started, hand-coding. Except, now I am really good at it.
Learn the basic nuts and bolts of html/css/javascript. Bookmark w3schools.
