Ignore When Clicked
Home Forums Puzzles Ignore When Clicked
  • #33232
    markwong
    Hi, i have a case like this:
    .For example OBJECT A is always in front of OBJECT B. But i want to call When Clicked for OBJECT B. The things is, is it not called because OBJECT A is blocking it.
    So my question is, is there any way to ignore When Clicked for OBJECT A? So it will trigger When Clicked for OBJECT B, although OBJECT A is blocking it
    #33243
    You can disable “when clicked” for certain objects with a little bit of code. See more info here: https://www.soft8soft.com/topic/clicking-through-geometry/#post-26333
    #33304
    markwong
    Hi Ivan,
    Thank you for the link! Appreciate
    Best Regards
