Identifying/setting coordinates in scene to prevent object entering a certain area?
Home Forums Puzzles Identifying/setting coordinates in scene to prevent object entering a certain area?
  • This topic has 11 replies, 3 voices, and was last updated 1 year ago by c4cc.
Viewing 12 posts - 1 through 12 (of 12 total)
  • #78956
    c4cc
    I’m trying to set coordinates/points in scene for an area that objects may not go through.
    1011
    1011
    My puzzles
    1011
    Yet it doesn’t work?
    :unsure:
    #78958
    Are the objects that you are trying to control….
    a) dynamic / controlled by physics
    b) animated via keyframes and played through the play animation puzzle
    c) animated by the animate parameter puzzle
    d) animated by JS
    e) controlled by the user via drag/move puzzles or other event based movement?
    d) and the object is not a camera .. correct?
    #78961
    c4cc
    Answers:
    a) No physics here
    b) they’re not animated, either by keyframes or the play animation puzzles
    c) No
    d) No
    e) objects are only controlled by event based movement, especially by user input (e.g., key,
    mouse)
    f) object here is not a camera.
    #78962
    deleted
    #78985
    Well at the moment…I am thinking this becomes a math problem and it gets more complicated based on whether the boundary objects are compound curves vs straight edges, 2D or 3D.
    An example of straight lines might be the perimeter of a house vs a figure 8 race track.
    Is this a single plane that your objects are moving across.. or its it more for your character that may have to move over terrain?
    #78991
    c4cc
    the coordinates are in straight lines, for rectangular areas.
    It’s for rectangular objects (e.g., platforms) my character is moving across. Don’t want it to pass through those objects.
    Sorry I didn’t clarify earlier.
    #78994
    Ok… just want to clarify. Your character will be limited to a rectangular space it can move across in X and Y and you want to prevent it from basically falling off the platform. The Z-Axis is not an issue correct?
    #78995
    c4cc
    Actually, the coordinates here are Y and Z axis, X-axis is not an issue, and even if the character falls off the platform, it’s fine.
    I just don’t want character going through the platform. Meaning I need coordinates around the platform that cannot be accessed by character
    #78998
    So the character can move freely and even off the plat form. But just can’t fall through it? Does the character jump?
    #78999
    c4cc
    Technically, it flies. But I just don’t want certain objects going through that platform
    #79009
    Based on this you could use bounding boxes to manage interference.
    Try this
    [ GLIFTEK ] Plugin Pack: BOUNDING BOXES
    #79082
    c4cc
    Sorry for the late reply, but on second thought, I managed to define a perimeter that (certain) objects are prevented going through, albeit crudely
    ol4x1
