I must be doing something wrong
Home Forums General Questions I must be doing something wrong
  • #1372
    kekers
    I just installed it looks very good but I’m not even able of giving two cubes mirror properties, I have made them as in b4web through the material selecting mirror and also using nodes with no luck, any help please!
    Thanks
    #1373
    kekers
    Also it is impossible to add an environment texture to work using the same method as i see in the examples :-(
    #1374
    For now unfortunally there is no realtime reflection, but we are working on that. All you see in the examples is pre-baked cube maps to imitate refraction with environment textures inside of object’s materials. Can you share with us an example of your scene may be we can find a solution?
    #1375
    kekers
    OK thanks for the asnwer, I suppose i’ll have to wait, anyway very good work on the visual logic. I also managed to understand the cubemap for the environment texture.
    Any rough plans on your roadmap? :)
    Thanks
