Home › Forums › General Questions › I can not see the verge3d examples correctly
- This topic has 8 replies, 2 voices, and was last updated 6 years, 1 month ago by
frg.
2019-01-09 at 8:15 pm #10461
frg
ParticipantHello everyone,first, excuse my English.
I am starting with this tool and I have encountered a problem that I can not solve.
I have noticed that some projects are not displayed correctly.
I am starting with this basic tutorial:https://www.youtube.com/watch?list=PLMnTV0uuRMhRn1QomhOqH4Rt_bSlDGXbP&v=ibPSGArAfJM but I have had to abandon it because I do not understand what I must do to make the object appear as shown in the tutorial.
It also happens with some examples of verge3d too.
Everything looks badly lit, too dark and I do not understand why.
I’ve tried on two different computers and the same thing happens.
I attach two images that I hope will help you understand the problem.Thank you very much.
2019-01-10 at 7:49 am #10473Yuri Kovelenov
StaffHi!
Sorry to hear that you’re having those issues.
Do other Verge3D demos work for you as expected?
What browser/OS are you using?
Can you please visit the webgl report page and attach the screen shot of how this page looks for you? Thanks!2019-01-10 at 12:53 pm #10488frg
ParticipantHi, thanks for the answer.
What browser/OS are you using?The demonstration of the city I think it looks good and the one of the cube also, the one of the teapot heater also.
In the example of the metalic cube with the monkey I can see that it is represented correctly but the background is always dark, when it should be gray.
But i have problems with a simple box without texture or material.
Finally, I found out that with the Microsoft Edge browser I have no problems.
But I would not like to use that browser. ;)When I compare the result in google chrome with microsoft edge it always happens that in the latter it looks brighter.
Attached image comparing both browsers with the teapot demonstration.I send you what you have asked me using the Chrome browser, the result with Microsoft Edge is the same
I have tried two computers, the first with Windows 7 and the other with Windows 10, the browsers are updated in both and the graphics drivers are also.
And i use the opengl version 3.3.
My graphics cards are not powerful, they are old, 5 years old, maybe there is the problem?Finally, I have activated the draft extensions in chrome but it does not solve anything
I think the problem is in the representation of the background, in the nightstand tutorial, i can not see the hdr background using chrome, but it is okey using Microsoft Edge. And that should affect the general lighting of the scene.
I hope there is some solution. For now, I will continue advancing with Microsoft Edge.
In any case, thank you very much.2019-01-10 at 1:23 pm #10497Yuri Kovelenov
StaffHi,
I see that you’re using Geforce 8400 GS video card which can work with WebGL only on top of older Direct3D 9 API on Windows. Unfortunately, WebGL in combination with such underlying graphics API appears to be very buggy as it is considered outdated and poorly tested by the browser vendors.
For this reason some advanced WebGL features/extensions may not work properly.
2019-01-10 at 3:02 pm #10503frg
ParticipantOk, thanks for the clarification.
So I must understand that Microsoft Edge uses the integrated graphics card, in my case, HD Intel® 4600.
Is it like that?
Because it’s the only explanation I see so that everything is seen correctly in Edge.
Thanks again
2019-01-10 at 3:12 pm #10504Yuri Kovelenov
StaffMS Edge works probably because it uses an alternative backend as compared to Chrome and Firefox
https://blogs.windows.com/msedgedev/2016/06/09/open-sourcing-the-microsoft-edge-webgl-glsl-transpiler/2019-01-10 at 10:04 pm #10512frg
ParticipantThank you very much, Yuri
In the computer of my home with windows 7 I have the same problem and I solved it by removing the hardware acceleration in Chrome.
Now looks good, but the problem is a very poor performance.I have a laptop third generation i7 with hd intel 4000 and a graphic card nvidia geforce gt 630m.
Luckily, I’ve been able to verify that everything is going great with Firefox. It looks good and with good performance.
But now, when I press the sneak peek button, google chrome is launched directly. I would like this to happen without the need to convert Firefox to my default Windows browser.
Is it possible to configure this option directly in Blender 2.79b by keeping Chrome as the default browser of windows 7?
I have searched for information but can not find anything, apologies for asking too much.
Thanks
2019-01-11 at 7:13 am #10516Yuri Kovelenov
StaffYou can try to set FF as default browser for Verge3D by using webbrowser.register() method. You can use it in the exec_browser function inside the addons/verge3d/custom_ui.py script.
2019-01-11 at 11:04 am #10522frg
ParticipantThank you very much! :)
