html elements break navigation?
Home Forums General Questions html elements break navigation?
  • #32020
    cfxs
    I have some html ui elements over the iframe.
    If I click and drag with my mouse to orbit the camera and the cursor moves
    over an html element the orbit stops. Is there a way to make the html elements not affecting the navigation? The html elements are Title animations and texts. They are not buttons which I understand would break the navigation.
    #32045
    the issue is that the dragging event registered on the canvas element inside your iframe and your navigation elements (it does not matter, buttons or texts) are located on top of that iframe. For such UI, the browser overrides events and does not allow them to be handled inside the iframe. You can fix it by placing your HTML UI inside the canvas container element (div with ‘v3d-container’ ID).
    X | FB | LinkedIn
    #32072
    cfxs
    thanks for your response. Do you mean I have to add the “v3d-container” as ID on the text objects? Like in my attached image? It doesn’t work unfortunately.
    #32082
    To overcome this issue, you should create the HTML UI elements inside your_app.html file.
    Another workaround is to create a smaller iframe element that is not overlapped by UI. See our Recliner demo.
