- This topic has 9 replies, 3 voices, and was last updated 2 years, 6 months ago by
kdv.
2022-08-25 at 4:47 am #55215
Robert Drew
CustomerHello
Currently pushing to finish for a client and the click html puzzles don’t seem to be working to initialize to the next page. Any help would be appreciated.
site: https://blacklightscreenplay.com/
You must be logged in to view attached files.2022-08-25 at 7:36 am #55228kdv
ParticipantFirst, the
tween cam
puzzle won’t work without thelook at
target.
Second, every frame you have an error in thesetCameraParam
function. Disable theevery frame
puzzle. The logic inside it looks strange a bit. It’s useless to limitmax angle
without limitingmin angle
and vice versa. Btw,orbit max vertical angle
can’t be more than 180. The vertical rotation is limited between 0 and 180. The horizontal rotation isn’t limited by default, from-Infinity
toInfinity
.You are trying to set a parameter that is not compatible with the “ORBIT” control mode.
2022-08-25 at 8:39 am #55232Robert Drew
CustomerAre these errors contingent on the simple html click working? Because the camera mouse move works on my end[ even on the published page],its the html that isn’t clicking through.
2022-08-25 at 9:15 am #55233kdv
ParticipantJust disable
every frame
puzzle and you’ll see if it were a cause of the problem.Puzzles and JS coding. Fast and expensive.
2022-08-25 at 10:30 am #55237Robert Drew
CustomerIt seems that the camera mapping isn’t the culprit. That puzzle is doing what it supposed to do. The click html puzzle is not working on the WordPress page. All three words initialize in the verge html but not on the actual WordPress site.
2022-08-25 at 11:13 am #55238Alexander Kovelenov
StaffHi, I see no URLs assigned on MUSIC and STORE, while SCREENPLAY requires double click and goes to the unavailable link https://blacklightscreenplay.com/?page_id=79.
2022-08-25 at 11:22 am #55242Robert Drew
CustomerRight because the screenplay link isn’t launching in a new tab on the WordPress page on my side. There should be page instantiations shouldn’t there be? I don’t even get a 404 call. The screenplay page doesn’t even instantiate.
2022-08-25 at 11:27 am #55243kdv
ParticipantWell, all three
setCameraParam
give this error in your case even on the localhost ))) So they don’t work, but the scene camera is moving. That means that they do nothing. Just remove them.Your
visual_logic.js
from the WordPress site doesn’t containwhen clicked
listeners. That’s why nothing happens. Onlywhen hovered
listeners are present and they work. Addwhen clicked
event lisneners, removesetCameraParam
puzzles and it will work.Puzzles and JS coding. Fast and expensive.
2022-08-25 at 11:32 am #55244Robert Drew
Customerse camera and all three links work on my localhost. there are click listeners in the puzzle. I need a cogent solution I’m not arguing I’m just relaying what I’m seeing.
2022-08-25 at 11:37 am #55246kdv
Participantthere are click listeners in the puzzle
They are not present on the WordPress site in
visual_logic.js
. Try to findregisterOnClick
here https://blacklightscreenplay.com/wp-content/uploads/verge3d/72/visual_logic.jsPuzzles and JS coding. Fast and expensive.
