How to write a program for the Puzzles generation with config or blender files ?
Home Forums Puzzles How to write a program for the Puzzles generation with config or blender files ?
  • #52809
    rampagedog
    Hello,
    I am a Blender user and new to Verge3D. I find I need to create a puzzle for each my application.
    Is there any way to streamline the process?
    For example, I have two blender files. The first one has a long animation and the animation is separated into two time periods, 1-100th frame, and 101-200th frames. The animation of the second one is separated into three time periods, 1-50th frame, 51-150 frame, and 151-200 frame.
    I want to create a script that will generate puzzles depending on the blender file or config file… I may create a json file has time periods. Read the json file to create the puzzle…
    #52818
    I think a simpler way would be to just use Verge3D/Three.js JavaScript API directly. You might get inspired by the code generated by relevant puzzles. You can find the codes in the file called visual_logic.js which is human-readable.
