How to use Verge3d in 2D layout configuration?
Home Forums General Questions How to use Verge3d in 2D layout configuration?
  • This topic has 1 reply, 2 voices, and was last updated 1 year ago by xeon.
  • #72471
    sumax
    We have some experience in developing applications for 3D models interactive using Verge3d. Currently, the client has provided us with the following link as a reference example, with a focus on the customization of 2D layout interaction in the configurator. Have any ideas on how to create this plane layout?
    https://konfigurator.vigor-equipment.com/index.php
    I’m not sure if Verge3D can be used to accomplish this or how to create it. Should we use spatial modeling with an orthographic camera, or are there other tools and plugins available?any similar works in Verge3d examples?
    Thanks, Max
    #72473
    Hi there,
    So there are many ways to answer your question.
    Can V3D be used to do this – yes
    Can V3D built in puzzles allow you do this – yes
    Can you use HTML/CSS/JS and V3D to accomplish this – yes.
    The site is pretty straight up PHP. If you are going to use V3D as your 3D viewer, then I would go the HTML/CSS/JS route to do the 2D portion rather than doing the same thing directly in V3D or using texture maps…. the site is very dynamic so your interface should be as well.
