how to Use SliderNumber and objectList for plugin UI
Home Forums General Questions how to Use SliderNumber and objectList for plugin UI
  • #64676
    aqiang
    The sliderNumber is a convenient and user-friendly UI element. When using it to create a plugin UI, how can I avoid errors? I’ve made some attempts below. Additionally, in previous versions, I was able to use <shadow type=”objectList”>, but it seems that it is not supported anymore in Verge3D 4.0, and it results in an error
    ` <value name=”THRESHOLD”>
    <shadow type=”number_slider”>
    <field name=”NUM” min=”0″ max=”10″ step=”0.1″>0.8</field>
    </shadow>
    </value>
    <!– <value name=”VALUE”>
    <field name=”FIELDNAME”><none></field>
    </shadow>
    </value> –>
    block.appendDummyInput()
    .appendField(new Blockly.FieldNumber(1), ‘slideNumber’);
    #64677
    See the Post-Processing puzzles and do the same to make it work.
    Do not use 4.3.0. Update to 4.3.1+
