How to use 3D procedural maps in Verge3D
Home Forums Graphics / 3ds Max How to use 3D procedural maps in Verge3D
  • #44826
    vern
    I’d like to use 3D procedural maps (like Advanced Wood in 3DS Max) but I don’t know to use it with Verge3D.
    I use it with Physical materials but Verge3D always throws an error when I go to export the .glTF or use Sneak Peek.
    Do I need to bake the texture somehow?
    #44831
    Unfrotunally, they are not supported yet.
    #44943
    vern
    I was able to bake the 3D map and send the model to Verge3D.
    I have the .glTF compatible button checked on the baked material but the option doesn’t come through. So the model is viewable in Verge3D, but not in AR.
    Is there a way to fix that?
    #44947
    jezuk
    Oh man, I was soooo looking forward to using Procedural Wood in 3DS Max for my Verge3D project :(
    #44948
    vern
    You still can but you can’t use a bitmap for the roughness map material input.
    I’m hoping they will tell me another workaround for now.
