How to show object dimension on screen e.g. length, width or thickness.
Home Forums Graphics / Blender How to show object dimension on screen e.g. length, width or thickness.
  • #40037
    simoon
    I am developing a custom make insole application. I can manipulate the size of the insole by push/pull an arrow. Now I would like to show the dimension of the insole onscreen. I have read most posts about dimension, ruler, configurator in the forum, but I cannot find any solution.
    You can view my project at http://digicare.com.hk/3d2
    Actually I am trying to make an application that looks like this https://youtu.be/Xq-hgbvUVt8
    I know slider is difficult to make at present. I would like to at least make a textbox that show the dimension of the insole when I push/pull it. It will be great if I can input some number into the textbox and the insole change accordingly. Thank you in advance.
    #40047
    I guess you want something like this? https://www.soft8soft.com/topic/parametric-examples-with-verge-3d/
    #40063
    visualizer
    Hi
    Simoon
    This is good example however it doesn’t display dimensions.
    Some days ago I came across this website which looks pretty impressive.
    https://canelaspring.es/en/producto/beoval
    May be you mean this perhaps. I did something similar some time ago just out of curiosity.
    #40064
    simoon
    Hi
    Simoon
    Thank you Visualizer, the site looks nice, unfortunately I need the changed size of morphed object update in real-time. Thank you very much for the information. :good:
    #40066
    simoon
    Thank you Mr. CEO. Exactly what I want to accomplish. Both of them look very professional. I believe they both call external function for manipulating the dimension, I think is JavaScript. Unfortunately my programming skill is still in the drag and drop puzzle level, unable to learn from their example.
    Are there any easier example I can follow? Thank you in advance.
