Home › Forums › Graphics / Maya › How to show image sequence in Maya scene? (movie)
- This topic has 7 replies, 3 voices, and was last updated 4 years, 6 months ago by
Yuri Kovelenov.
2020-10-13 at 6:32 pm #34118
alexxis
ParticipantHello,
I have tested a scene with short movie sequence (JPG sequence) inside the Maya scene on a plane.
It did not work with scroll-animation, only showed the first picture.
Is there a way to solve this? Or should it take a different image format?
Thanks2020-10-14 at 6:03 am #34122Mikhail Luzyanin
StaffIt did not work with scroll-animation, only showed the first picture.
Unfortunally, sequence not supported (and I don’t that that it will be supported in near future). The only way to get it work is to convert to any video format and run it with special Play Video Puzzle.
2020-10-14 at 7:47 am #34137alexxis
ParticipantThanks for reply.
1.) I think, that Picture Sequence would be the most important feature for 3D scenes, because it enables to mimic every kind of 3Dscene: Just by importing this as an image plane. Just think of complex fluid or particle simulations, which you will never be able to support.
And it even could be used to blend (Baked) textures.
Everything else you develope will enable just a small enhancement in comparison to something that could be a workaround for everything, which isn’t supported yet.2.) I did not see an example scene or tutorial for “video puzzle”. In the examples there is not Maya file. Can you provide a link for it?
Thanks
2020-10-14 at 7:53 am #34139Mikhail Luzyanin
StaffI think, that Picture Sequence would be the most important feature for 3D scenes
But it will be very slow for WebGL.
There’s no Maya scene for now, but you can read how to use it in the documentaion.
2020-10-14 at 8:14 am #34141alexxis
ParticipantPicture Sequence:
You can show great artworks even with very slow performance.
To blend slowly between pictures can be achieved also with 4 FPS.
And even if it has a flip-book style, when it enables to show all kinds of portfolio works in an interactive way, it’s great.Video documentation:
I did not understand how you assembled the video on the 3D-TV in the example scene… If you did not in Maya, how did you else?Thanks
2020-10-14 at 11:46 am #34151Yuri Kovelenov
StaffHi,
the setup is rather simple: you first assign a texture to your material in Maya. Then export to Verge3D, and in Puzzles editor, use the puzzle replace texture to assign a video. See the source files of the demo Video Texture (sorry no Maya file as this scene was assembled in Blender).
2020-10-14 at 12:19 pm #34154alexxis
ParticipantOk thanks, that sounds easy.
If there would be for a standard Video a Scroll-animation possible (which I have seen several times in online magazines, so it can’t be something hard!) this could already solve some tasks, which I mentioned above
2020-10-14 at 12:43 pm #34155Yuri Kovelenov
Staff -
