How to set camera parameter in puzzle?
Home › Forums › Puzzles › How to set camera parameter in puzzle?
  • #42015
    Gerome Gan
    A little help please??
    I have a camera with a certain parameter limit (3ds max).
    The camera tweens to another location.
    Once it arrive at the new location, is there a way to reconfigure a new parameter limit for it?
    This way, I can tween the camera around the scene with different set of parameter limit.
    No, using active camera will not do as I want to have the animated camera tweening effect.
    Currently my solution is to tween the camera to another camera and swap the camera once it arrived.
    Thanks in advance.
    #42036
    The only way is to create multiple amount of Cameras in the scene with different params and switch between them.
    #42046
    Gerome Gan
    Ok got it. So far that solved it for me Thanks.
    #42459
    Ralf
    In my case this didn’t solve the problem.
    I have several Orbit-Cams with different parameters. It is possible to tween from one cam to another.
    Because the startposition has to be defined, I have to reset the orbit-cams somewhere.
    The only way I found is to reset the active cam by tween in 0 sec. The causes a flicker if the cam was moved before.
    Is it possible to tween or reset an inactive cam. This would solve the flicker.
    Thanks Ralf
    #42480
    You can use snap puzzle for inncative camera.
    #42544
    Ralf
    Okay, I tried snap and it works perfect for the Cam-position. Is it possible to set the ‘lookAt’ of an inactive camera as well?
    thanks, Ralf
    #42545
    Ralf
    I finally managed to change the orbit-cam limits by exec script puzzel. :yahoo:
    app.controls.enableZoom = true;
    app.controls.enablePan = false;
    app.controls.minDistance = 10;
    app.controls.maxDistance = 15;
    //console.log(app.controls.getPolarAngle()); // in case you are lost
    app.controls.minPolarAngle = 0.6;
    app.controls.maxPolarAngle = Math.PI;
    //console.log(app.controls.getAzimuthalAngle ());
    app.controls.minAzimuthAngle = - Infinity;
    app.controls.maxAzimuthAngle = Infinity;
    #42554
    Gerome Gan
    If you are talking about (for example). Tweening Camera1 to camera2 then do a switch active to camera2.
    But now the Camera1 position is no longer at it’s previous default position. I had problem with resnapping it back to it’s original position. As “snap” camera target cause a bug where the camera clipping plane value will change (I have created another post for this).
    Instead of using snap puzzle, I copy the original camera1 positon+target XYZ value in 3ds max and use “set position” puzzle.
