Home › Forums › Programming › How to reset camera controls that has been changed through code
- This topic has 5 replies, 2 voices, and was last updated 2 years, 1 month ago by
kdv.
2023-02-14 at 9:46 am #60381
Ilia Bg
ParticipantUsing panorama view example
i created a panorama viewer, but the problem is, when i want to switch scene to a normal one, which contains a 3d model and i want to have back default OrbitControls for camera, i can’t find a way to do it, so i just stuck with those settings for Panorama Viewapp.controls.enableZoom = false; console.log(app.raycaster); let isUserInteracting = false, onPointerDownMouseX = 0, onPointerDownMouseY = 0, lon = 0, onPointerDownLon = 0, lat = 0, onPointerDownLat = 0, phi = 0, theta = 0; init(); animate(); function init() { const container = document.getElementById("v3d-container"); app.renderer.setPixelRatio(window.devicePixelRatio); app.renderer.setSize(window.innerWidth, window.innerHeight); container.appendChild(app.renderer.domElement); container.style.touchAction = "none"; container.addEventListener("pointerdown", onPointerDown); document.addEventListener("wheel", onDocumentMouseWheel); } function onPointerDown(event) { if (event.isPrimary === false) return; isUserInteracting = true; onPointerDownMouseX = event.clientX; onPointerDownMouseY = event.clientY; onPointerDownLon = lon; onPointerDownLat = lat; document.addEventListener("pointermove", onPointerMove); document.addEventListener("pointerup", onPointerUp); } function onPointerMove(event) { if (event.isPrimary === false) return; lon = (onPointerDownMouseX - event.clientX) * 0.1 + onPointerDownLon; lat = (event.clientY - onPointerDownMouseY) * 0.1 + onPointerDownLat; } function onPointerUp() { if (event.isPrimary === false) return; isUserInteracting = false; document.removeEventListener("pointermove", onPointerMove); document.removeEventListener("pointerup", onPointerUp); } function onDocumentMouseWheel(event) { const fov = app.camera.fov + event.deltaY * 0.05; app.camera.fov = v3d.MathUtils.clamp(fov, 30, 75); app.camera.updateProjectionMatrix(); } function animate() { requestAnimationFrame(animate); update(); } function update() { if (isUserInteracting === false) { lon += 0; } lat = Math.max(-85, Math.min(85, lat)); phi = v3d.MathUtils.degToRad(90 - lat); theta = v3d.MathUtils.degToRad(lon); const x = 500 * Math.sin(phi) * Math.cos(theta); const y = 500 * Math.cos(phi); const z = 500 * Math.sin(phi) * Math.sin(theta); app.camera.lookAt(x, y, z); app.renderer.render(app.scene, app.camera); }
2023-02-14 at 11:29 am #60388kdv
Participantcan’t you use two cameras and switch between them? like here https://v3d.net/ctv
That’s how it can be done quickly in Verge3D. Just nearly an empty scene and two cameras.
2023-02-14 at 12:50 pm #60389kdv
Participantduplicated deleted
2023-02-15 at 3:43 am #60412kdv
ParticipantBut if you insist on using the code above (which is very excessive) then you should save the current controls as a variable to restore it afterwards.
app.controls.enableZoom = false; //disable zooming const prevControls = app.controls; //save current controls app.controls = null; //disable current controls const container = app.container; let isUserInteracting, onPointerDownMouseX = 0, onPointerDownLon = 0, onPointerDownMouseY = 0, onPointerDownLat = 0, lon = 0, lat = 0, phi = 0, theta = 0; init(); update(); function init() { container.addEventListener("pointerdown", onPointerDown); container.addEventListener("wheel", onMouseWheel); container.addEventListener("dblclick", function() { if (app.controls) { app.controls.enableZoom = false; //disable zooming app.controls = null; update(); } else { app.controls = prevControls; app.controls.enableZoom = true; //enable zooming } }); } function onPointerDown(event) { if (app.controls) return; isUserInteracting = true; onPointerDownMouseX = event.clientX; onPointerDownMouseY = event.clientY; onPointerDownLon = lon; onPointerDownLat = lat; container.addEventListener("pointermove", onPointerMove); container.addEventListener("pointerup", onPointerUp); container.addEventListener("pointerleave", onPointerUp); } function onPointerMove(event) { lon = (onPointerDownMouseX - event.clientX) * 0.1 + onPointerDownLon; lat = (event.clientY - onPointerDownMouseY) * 0.1 + onPointerDownLat; update(); } function onPointerUp() { isUserInteracting = false; container.removeEventListener("pointermove", onPointerMove); container.removeEventListener("pointerup", onPointerUp); container.removeEventListener("pointerleave", onPointerUp); } function onMouseWheel(event) { if (app.controls) return; const fov = app.camera.fov + event.deltaY * 0.05; app.camera.fov = v3d.MathUtils.clamp(fov, 30, 75); app.camera.updateProjectionMatrix(); } function update() { lat = Math.max(-85, Math.min(85, lat)); phi = v3d.MathUtils.degToRad(90 - lat); theta = v3d.MathUtils.degToRad(lon); const x = 500 * Math.sin(phi) * Math.cos(theta); const y = 500 * Math.cos(phi); const z = 500 * Math.sin(phi) * Math.sin(theta); app.camera.lookAt(x, y, z); }
2023-02-15 at 1:26 pm #60431Ilia Bg
ParticipantYour code worked like a charm, big big thanks
2023-02-15 at 1:46 pm #60433kdv
ParticipantAlso you can remove
isUserInteracting
variable. It’s not used and not needed.Puzzles and JS coding. Fast and expensive.
