Home › Forums › Graphics / Blender › How to preprare my blender file for export in a browser
- This topic has 15 replies, 2 voices, and was last updated 7 years, 1 month ago by
Mikhail Luzyanin.
2018-02-23 at 11:03 am #2351
vincent
CustomerWith version 2.0, we can see that the file pbr (suzanne) is done under cycle, but I can not seem to make the same settings in a new file. The export gltf in my browser remains empty.
In other words, how to use the nodes under Verge3D.
2018-02-23 at 11:49 am #2353Mikhail Luzyanin
StaffCan you attach the file example?
2018-02-23 at 12:55 pm #2354vincent
CustomerDo you need only the blender file ?
2018-02-23 at 1:15 pm #2356vincent
CustomerIt’s very strange because if I make a “append” inside Pbr it’s ok. But If I build a new blender file it’s blank, with my egg (I see nothing).
Where are the perfect setting when you begin the work flow ?2018-02-25 at 7:40 pm #2377Mikhail Luzyanin
StaffSorry ofr late response, are you working in the cycles mode or Verge3D enige mode? For PBR you should work in Cycles engine mode.
2018-02-26 at 8:27 am #2389vincent
CustomerOk I saw this update but, I don’t see always anything in my browser. The background world hide something…
2018-02-26 at 8:45 am #2396Mikhail Luzyanin
StaffOk I saw this update but, I don’t see always anything in my browser. The background world hide something…
Sorry, I still can’t understand the problem. Can you attach a blend file with textures, make a few screenshots from the browser and write step by step how do you prepare the model for export.
2018-02-26 at 8:50 am #2398vincent
CustomerDid you open the 366 file? when I open it with sneak peak, nothing is displayed in my browser. Yet it is the same setting as pbr with suzanne. What do you see on your side, normally it’s a stone egg?
2018-02-26 at 9:03 am #2402Mikhail Luzyanin
StaffDid you open the 366 file? when I open it with sneak peak, nothing is displayed in my browser.
Yes I’ve opened it but there is no textures, I cannot exactly to do the right testing without textures.
2018-02-26 at 9:23 am #2411vincent
CustomerI send the texture outside the blend file, What can I do ? There is one for me.
2018-02-26 at 9:44 am #2415Mikhail Luzyanin
StaffI send the texture outside the blend file, What can I do ? There is one for me.
Where did you send it? I haven’t found it in zip file.
2018-02-26 at 10:10 am #2422vincent
Customerhttps://we.tl/3vPx6XQwIn
You can use this link to find the HD textures.2018-02-26 at 10:59 am #2430Mikhail Luzyanin
StaffOk, we get it, thank you! We will look at it more closely during some period of time to find where the issue.
2018-02-26 at 12:44 pm #2433vincent
CustomerIf I know where do you work in Russia, I can synchronize my work with the jet lag. Moscou… Saint-Pétersbourg ? Thank you for you feed back.
2018-02-26 at 3:07 pm #2459Mikhail Luzyanin
StaffIf I know where do you work in Russia, I can synchronize my work with the jet lag. Moscou… Saint-Pétersbourg ? Thank you for you feed back.
We are working at Moscow from 10 am to 7 pm.
