how to make camera change when click on “button” created in webflow.
Home Forums Puzzles how to make camera change when click on “button” created in webflow.
Viewing 15 posts - 1 through 15 (of 27 total)
  • #28596
    hella
    I created a webflow button and i want to assign the button to change camera when click. whats the puzzle for it? can anyone share an example?
    for example i want ” on even when click, “button 2” change camera .
    so it would look at other camera when i click the button how do i assign this in the puzzle?
    #28604
    You need to use Set Active Camera puzzle with the new camera to change it.
    #28610
    hella
    can you give an example?
    #28611
    It’s veru simple Just conncet a new camera to Set active camera puzzle and that’s all.
    #28612
    hella
    I have 3 camera in blender and they are position in different locations all the camera are also pointed to look at an empty plane.
    I have 3 buttons that i created in webflow, I want to assign each one of the camera to look at a different empty plane each time I click on it. What puzzles do I need?
    #28613
    hella
    Heres the puzzle i did and it not working
    #28615
    hella
    okay so heres what i did when i demo it still doesnt work
    #28617
    May be something wrong with ID, try to hange them on something like “button_3” in webflow and puzzles.
    #28619
    hella
    once i assign the puzzle do i have to re-embeded in the webflow and then save it and then change the ID to button_3 or can i just change the ID and then just export the code to the application?
    #28620
    hella
    still not working I change all the ID to their designated “button_1” for example.
    #28621
    hella
    heres what I did. I even re-embeded it before changing the ID.
    #28623
    hella
    i opened this in visual studio
    #28625
    Kim Winberry
    Ok, I did something similar where I had a painting (Apple). When you click on the painting, It changes cameras to the one that is pointed at the painting (Cam Apple) and then it adjusts so that the painting is completely in frame
    #28627
    I do not see a ID in your code. Button_2 name assigned only to Class. Please add and ID for element first.
    #28629
    hella
    okay ill go back to webflow and set an ID selector maybe this is the problem. ?
