How to listen to mouse double click rather than click?
Home Forums Programming How to listen to mouse double click rather than click?
  • #33411
    derekwang0605
    Suppose I have more than hundreds of objects need to be listened to the mouse clicks.How to find the its parent group name by clicked object? Also how to register double clicks if possible?
    registerOnClick([‘ALL_OBJECTS’], function() {
    console.log(‘clickedobject=’,_pGlob.pickedObject);
    }, function() {});
    Also how to block the web user to know your js code by F12?
    #33442
    you can find the referecne to the object by its name, then find its parent through API
    Double clicks should be coded manually, no support in puzzle yet, sorry
    you can use a JS minifier for that
    #33447
    derekwang0605
    Thanks! Indeed helpful!
    #33463
    derekwang0605
    Indeed helpful!
