How to limit the camera panning
Home Forums General Questions How to limit the camera panning
Viewing 13 posts - 16 through 28 (of 28 total)
  • #55846
    David Yanez
    Wow, thanks
    kdv77kdv! This is exactly what I was looking for. How do you set the camera view offset?
    #55850
    let width = app.renderer.domElement.width;
    let height = app.renderer.domElement.height;
    let panLimitX = width / 2;
    let panLimitY = height / 2;
    let movementX, movementY, offsetX, offsetY, prevX, prevY;
    const pixelRatio = app.renderer.getPixelRatio();
    const isMobileDevice = v3d.Detector.checkAndroid() || v3d.Detector.checkIOS();
    const v3dCanvas = app.controls.domElement;
    app.camera.setViewOffset(width, height, 0, 0, width, height);
    window.addEventListener('resize', function() {
    }, false);
    if (isMobileDevice) {
        v3dCanvas.addEventListener('touchstart', function() {
            if (event.touches.length != 2)
                return;
            prevX = event.touches[0].pageX;
            prevY = event.touches[0].pageY;
        }, false);
        v3dCanvas.addEventListener('touchmove', setCamOffsetMobile,  false);
    } else {
        v3dCanvas.addEventListener('mousemove', setCamOffsetDesktop,  false);
    function setCamOffsetDesktop() {
        if (event.which < 2)
            return;
        setCamOffset(event.movementX, event.movementY);
    function setCamOffsetMobile() {
            return;
        movementX = event.touches[0].pageX - prevX;
        movementY = event.touches[0].pageY - prevY;
        setCamOffset(movementX, movementY);
    function setCamOffset(moveX, moveY) {
        offsetX = app.camera.view.offsetX - moveX * pixelRatio;
        offsetY = app.camera.view.offsetY - moveY * pixelRatio;
        offsetX = v3d.Math.clamp(offsetX, -panLimitX, panLimitX);
        offsetY = v3d.Math.clamp(offsetY, -panLimitY, panLimitY);
        app.camera.setViewOffset(width, height, offsetX, offsetY, width, height);
    #59601
    saalemv3d
    Good solution but did you check it on the Firefox browser? It is not working.
    #59602
    it’s the problem of FireFox. It can’t read event.which properly.
    Replace if (event.which < 2) with if (event.buttons < 2) and it will work in FireFox too.
    P.S. The demo has been updated. Works in the latest FireFox.
    https://v3d.net/ajo
    #59657
    saalemv3d
    Great :good: , it works now.
    Thanks
    #63563
    saalemv3d
    Hi kdv,
    Have you checked this solution with the taller models, for example, building?
    When you zoom in more, the visible part of the model scales (enlarges) too much.
    Thanks
    • This reply was modified 1 year, 10 months ago by saalemv3d.
    #63565
    What should I see on that screenshot? The code above is not about zooming. It’s about changing the scene camera view offset (pseudo-panning). Remove that code and you’ll still get the same result when zooming too close.
    #63567
    saalemv3d
    In the screenshot, the top part of the model is scaled (bigger than normal) after zoom-in. The main reason to use your solution is to enable a limited pan. So, if we remove the camera view offset code, we lose the limited pan functionality.
    #63568
    Once again: it’s not panning. Just compare it with the original panning and you will see the difference.
    Where? The buildings are absolutely parallel to the screenshot’s sides.
    #63570
    Panning.
    The camera view offset.
    #63573
    saalemv3d
    Thanks for the reply.
    I added the different screenshots with the illustrations over the images.
    #63576
    That’s the perspective camera distortion depending on its FOV. When you use panning you really move the camera in the scene’s world space and the distortion is always relative to the center of the screen (the first screenshots). When you use the view offset you move nothing. You see the model as if it’s in the center but with the screen offsets in px. It’s not panning.
    #63579
    saalemv3d
    Thanks for the explanations.
    I will try to use Blender constraints and will see if I can get what I am looking for.
