How to keep transparent background in Iframe
Home Forums General Questions How to keep transparent background in Iframe
  • #44115
    tdelcroix
    Hello, I host my 3d verge models on website and I would like to put them on another website via an iFrame but when I do that I lose the transparency of the background.
    How can i keep the transparency in background
    #44118
    Hi there,
    I am sure you have tried this but just in case.
    Within the Init Tab.. you can try the “Config Application” puzzle. It has a transparent background option. You can then use the parent doc to control the background image.
    #44122
    tdelcroix
    Hello, first of all thank you for your answer.
    Yes I have already tried the ‘Config Application “I see the last one on the app manager page but when I put the url in an iFrame I don’t have the background transparency.
    How can i do this with parent doc? it’s my first time on Verge 3d and i’m not a programmer
    #44125
    tdelcroix
    I found the solution, the “webflow” css file had a hex code without transparency so I change it manually with an html editor.
    thx again
