How to create a picture annotation with puzzles?
Home Forums Puzzles How to create a picture annotation with puzzles?
Viewing 15 posts - 1 through 15 (of 16 total)
  • #30618
    chornblow
    Hi guys,
    Sorry a bit of newbie question but I’m wondering if it’s possible to create an annotation with puzzles that shows a picture when expanded rather than text?
    I’ve tried adding the file path within the text field with no success. I don’t think I’m doing this wrong as I’ve tried writing out the file path a few different ways: ./picture.jpg and just: picture.jpg
    Any help is much appreciated.
    Many thanks,
    chornblow
    #30621
    try it this way:
    <img src="path/to/your_image.jpg">
    #30623
    chornblow
    Worked perfectly, thanks for the quick response Yuri.
    #30626
    glad it helps! :good:
    #30836
    vivektrivedi478
    I am having the same problem, I attached a screenshot, @chornblow as your problem is solved can you please help me to understand what I did wrong.
    #30849
    looks like you are using an absolute path to your image file – you might try a relative path instead
    https://www.w3schools.com/html/html_filepaths.asp
    #30850
    vivektrivedi478
    Thanks, Worked perfectly :yahoo: :yahoo:
    #30852
    :good:
    #30867
    vivektrivedi478
    I done same things to apply video on annotation, and it’s worked perfectly,
    But after publishing video is not playing. attaching screenshot for the same.
    #30876
    can it be the file path again?
    #30877
    vivektrivedi478
    I don’t think is path problem as in preview it work perfectly,
    problem started after publishing.
    https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:66598abf5f/applications/NEW%20UI%20FINAL/index.html
    #30881
    from the browser console (F12) I see that the mp4 file is not found on the server. Please double check the path (also beware that file names are case-sensitive).
    #30883
    vivektrivedi478
    Thank you sir,
    case sensitivity is a issue after renaming VID5.mp4 to vid5.mp4, it’s worked perfectly.
    thanks again :yahoo: :yahoo: :yahoo:
    #30913
    glad it helps!
    #64711
    shawndslayer
    Hi I am actually quite newbie with this, how did you place a video or image in the annotation? I tried the file path that I saw, but it still didn’t work. If it’s possible, do you think you can help, thank you
