How to control RGB colour using HTML range slider?
Home Forums General Questions How to control RGB colour using HTML range slider?
  • #64463
    mashud008
    I’m sharing a video. I want to create a 3d room configuration. It will be configured only with the lighting system using an HTML range slider. Must control the light and RGB color via HTML UI.
    Is it possible? How can I do it?
    • This topic was modified 1 year, 9 months ago by mashud008. Reason: adding an images
    #64470
    Only one range slider is supposed to be used?
    #64479
    mashud008
    One slider control RGB light brightness and darkness color, and another slider control the RGB color
    #64480
    Use HSV format. H – color or hue (0-1), V – color intensity (0-1), S – always 1. Then convert to RGB format and apply via puzzles.
    #64486
    mashud008
    than you friend, I’ll try to this
