How to change HDRI with puzzles, and use a higher resolution?
Home Forums General Questions How to change HDRI with puzzles, and use a higher resolution?
  • #72191
    domjasper
    Hi everyone,
    I am struggling to create a puzzle which allows a user to select an HDRI from a list of options.
    I would like to use the HDRI as a background as well, so I need it to be high resolution.
    Is this possible?
    TIA
    #72197
    Pandern
    Use the replace texture puzzle to change hdri.
    I used it in this example: car configurator
    I wouldn’t use high resolution HDRI for environment, but rather make JPG’s and map them to geometry that you hide/unhide. In the example given above i used a flat surface for ground and a cylinder for the rest. But the easiest is to use a sphere.
    Se image for the puzzle used
    • This reply was modified 11 months, 3 weeks ago by Pandern.
    #72210
    domjasper
    Thank you! Very helpful. Will give it a test.
    How do you make the image emit light like an HDR would?
    #72246
    Pandern
    The geometry with with the images is in addition to the regular HDRI environment. They don’t emit light. Nor do they receive any lighting as I used a ‘surface shader’ (maya) and turned off ‘cast shadow’ on the geometry.
    Create a sphere that encompasses the scene and cameras. Reverse the normals so only the inside of the sphere is visible using a 1-sided material. Map a jpg version of the HDRI on to the sphere and and position it to align to the environment HDRI so that the lights and reflections matches both HDRI and the sphere.
    Edit: this tutorial shows how to project textures, in blender, to geometry in a scene from a hdri. https://www.youtube.com/watch?v=rrZiSwXoBVA
