How to Build for Mobile with Cordova?
Home Forums General Questions How to Build for Mobile with Cordova?
  • #50667
    renderkick
    Hi, Verge3D newbie having issues with trying to create a test build for Android with Cordova.
    I’ve followed the instructions available here to the letter: https://www.soft8soft.com/docs/manual/en/introduction/Creating-Mobile-Apps.html and despite serveral hours trying to troubleshoot and multiple attempts on both Windows and Ubuntu I have failed miserably.
    The command: cordova requirements returns this:
    Requirements check results for android:
    Java JDK: installed 1.8.0
    Android SDK: installed true
    Android target: not installed
    Command failed with ENOENT: avdmanager list target
    spawn avdmanager ENOENT
    Gradle: installed /opt/gradle/gradle-7.4.1/bin/gradle
    Some of requirements check failed
    Whilst the following command cordova emulate android returns:
    A problem occurred evaluating script.
    > Ambiguous method overloading for method io.github.g00fy2.versioncompare.Version#isLowerThan.
      Cannot resolve which method to invoke for [null] due to overlapping prototypes between:
            [class io.github.g00fy2.versioncompare.Version]
            [class java.lang.String]
    Are the instructions at the link above in need of updating? Or I am doing something wrong? I’ve installed the latest versions of Android Studio, Cordova and Gradle. Perhaps there’s a specific combination of versions for those tools required?
    Any help would be much appreciated.
    Thanks all
    #50710
    renderkick
    Never mind I figured it out myself. I’d accidentally installed the lastest Java SDK (version 18) instead of the JRE version lower down the page! I also had to rename a couple of files in the Android Studio package for a sucessful build but I got it working eventually.
    #50738
    sorry for not responding earlier…glad you worked it out! :good:
    #60870
    echokhan
    @renderkick was so happy to see you post on this! I have been running into the same snag… are you able to share what specific rename edits you made in Android Studio to get the apk to build? I have the exact same problem with Gradle requirements returning an AVD manager error.
