Home › Forums › General Questions › How to bring in blender objects from cgtrader?
- This topic has 15 replies, 2 voices, and was last updated 3 years ago by
pekkizz.
2022-03-02 at 1:53 pm #49828
pekkizz
CustomerHi!
I am a total newbie, just installed the Vergo3d for blender.
Now in the main tutorial, the “collection witch contains all parts of the model” is imported with the command “Append”:
But how do I manage to import the kitchen assets I just bought from CGtrader? They are just for example “modern_kitche.blend”, opened here:
https://catchline.fi/toveri/kitchen.jpgBut if I try to bring this in, like the guy bring in the swiss knife in the above tutorial, I get the error: “..not a library” screenshot here:
https://catchline.fi/toveri/not-a-library.pngSo how do I convert the *.blend files I just bought to blenders “library” format?
Pekkizz
2022-03-02 at 3:06 pm #49831Mikhail Luzyanin
StaffCan you record a video how you do it and share here? The full process.
2022-03-02 at 4:24 pm #49836pekkizz
CustomerHi!
thanks!
2022-03-03 at 7:28 am #49851Mikhail Luzyanin
Staff1. In the blend file the object (kitchen) not in the collection, but you attaching collection, so you need to put the object in it first.
2. You use Sneak Peak, but it’s only for preview of the model, you need to use Export to Verge3D (gltf) to see your model in the application.All this basic things was explained in details in the Swiss Army Knife tutorial. Please, watch it more carefully.
2022-03-03 at 7:32 am #49852pekkizz
CustomerThank you very much.
About your answer 1:
Can I import also object, or do I have to import always collection?
I am very new to blender, sorry but I learn fast.I watch now the knife tutorial again :)
Pekka
2022-03-03 at 7:34 am #49853Mikhail Luzyanin
StaffYou can import (attach or link) object or even mesh, but if ther is multiple amount of objects in the scene then better to import collection.
2022-03-03 at 7:37 am #49854pekkizz
CustomerOk, I will then always do this collection way, since I focus on using stuff from CGtrader / other blender and Omniverse artist.
In the tutorial he ( maybe you ? ) bring in only the collection. So the item I bought from CGtrader does not have anything in collection as you told me, so I now learn how to do that in blender. Here we go!
2022-03-03 at 7:41 am #49857pekkizz
CustomerOh, it is a collection already in the kitchen file I bought!
It must be something else then.see the attachment..
I now study this video:
You must be logged in to view attached files.2022-03-03 at 7:58 am #49862pekkizz
CustomerPlease see this:
Ok, I opened the kitchen scene, made a new collection from the glass object. saved.
Then I created a new vergo blender scene “pekka4” and deleted the default cube, imported the glass gollection. cool! I save the scene.
But now when I view the “pekka4” , I still see the default cube.
What am I doing wrong?
2022-03-03 at 8:00 am #49863pekkizz
CustomerAh! I need to export it over the old, saving is not enough :P
I try this.
2022-03-03 at 8:03 am #49864pekkizz
CustomerYes, I see the glass now there!
I continue by studying how to bring in the full kitchen..2022-03-03 at 8:17 am #49865pekkizz
CustomerHello!
It comes in just fine!! Vergo3d is soooo good thank you I am going to purchace this to our startup CineShare:)But see this please:
I have the blender kitchen model on the left and kitchen sink is just ok.
But in the vergo web page ( app and scene ) it is hided by the worktop marble surface.. How to solve this problem?
2022-03-03 at 8:25 am #49866Mikhail Luzyanin
StaffCan’t see how it’s made because have no model to watch the full structure, but may be it’s made using boolean modifier try to check checkbox in the verge3d settings of exported file called Bake Midifier may be it can help.
2022-03-03 at 8:38 am #49870pekkizz
Customerok, I tried to search for the option for 15 min.
Browsed / searched for tutorials for “bake” and not found this.Please can you tell me where this verge3d settings of exported file is?
2022-03-03 at 8:56 am #49871Mikhail Luzyanin
StaffRender Properties tab | Verge3D Settings section
Yes, but not all part of the model in the collection – it’s also can be seen on the screenshot you provide.
