How to Be Select object and change colors with html elements?
Home Forums Puzzles How to Be Select object and change colors with html elements?
  • #70831
    mashud008
    Hi
    V3D expertise and developers all are well.
    If anybody help me this project, it will be glad.
    I have shared two images and Project File. I want to be able to change the color according to the shape of the object from the selected connector on the right side when I select any object in the 3D space. For example, I select the Tours object or any object and then configure it with the color, I want from the connector on the right side. Again, suppose I selected the Sphere object, and I will be able to change the colors of the Sphere from the connector part. I’ve been experimenting with different types of puzzles for two days, but I can’t seem to get this to work. Actually, I am a 3D modeler so zero knowledge about programming. If anyone can help me how to do this would be greatly appreciated.
    thank you
    #70834
    mashud008
    any one can download this project file.
    pick object
    #70835
    well…i will check it out
    • This reply was modified 1 year, 1 month ago by xeon.
    #70838
    The problem is your picked object puzzle….replace it with the 3D object selector Torus or what ever is defined in the When Clicked puzzle.
    #70841
    Never ever use event listeners inside another event listener.
    #70843
    Given your statement of “Never”….how do you use an “on event of input” puzzle as I havent found a solution that allows me to have the “on event of input” puzzle isolated as you have shown.
    sample here:
    https://v3d.net/t69
    #70844
    this way, as a usual event listener
    Upload that app in zip and I’ll show you how )))
    #70845
    https://v3d.net/t7n
    I should have been more specific…as it relates to the event within an annotation.
    #70851
    well, in your case you remove annotations together with event listeners and that’s quite acceptable.
    but you could do the job without “remove/add annotation” every time you click the cubes.
    #70857
    I like the way you did this without the remove/add annotation…. seems alot cleaner…thank you.
    #70860
    mashud008
    Hi everyone.
    Really appreciate it. thanks all of the v3d members. I have shared two images again. Here you have very nicely explained to me how to change the material by selecting the object. But I need to change only the sphere object color for the sphere from the sidebar on the right side. Again, for the tours object, if you click only on the tours section, those objects will replace the colors. That is, there are options to change three types of objects on the right side. That is, when I select the object, the color will change if I select the element of that object on the right side. Another thing is that I can download my configuration data into a “json” file. Is there a way that the “json” file will be downloaded and emailed at the same time?
