How to avoid CSS conflict and show the buttons?
Home Forums Programming How to avoid CSS conflict and show the buttons?
  • #42550
    derekwang0605
    I am using layui but I can not show the buttons.
    <link rel=”stylesheet” href=”layui/css/layui.css” media=”all”>
    <link rel=”stylesheet” type=”text/css” href=”myproject.css”>
    <button class=”layui-btn layui-btn-primary layui-border”>Button</button>
    <button class=”layui-btn layui-btn-primary layui-border-green”>Button1</button>
    <button class=”layui-btn layui-btn-primary layui-border-blue”>Button2</button>
    <script src=”layui/layui.js” charset=”utf-8″></script>
    #42566
    Hi! That’s probably because the standard element #v3d-container (which contains the 3d scene) is rendered above the buttons. That happens because it has the following CSS rules applied:
    position: absolute;
    z-index: 0;
    To fix that you can just put the buttons right inside #v3d-container. Or, alternatively, leave them as is but add CSS rules like “position: relative; z-index: 1;” so they will be rendered above #v3d-container.
    #42628
    derekwang0605
    To fix that you can just put the buttons right inside #v3d-container. Does that mean I change to below:
    <button id=’v3d-container’ class=”layui-btn layui-btn-primary layui-border”>Button</button>
    #42630
    No, not exactly what I meant. I was referring to moving the buttons inside the “v3d-container” element:
    <body>
      <div id="v3d-container">
        <div id="fullscreen_button" class="fullscreen-button fullscreen-open" title="Toggle fullscreen mode"></div>
        <button class="layui-btn layui-btn-primary layui-border">Button</button>
      </div>
    </body>
