Home › Forums › Puzzles › How make text from div in separate HTML file display in specific screen position
- This topic has 2 replies, 2 voices, and was last updated 5 years, 10 months ago by
jaspixel.
2020-11-14 at 7:55 pm #35331
jaspixel
CustomerHi,
Apologies, but I have trawled the tutorials and not found a specific guide for this one. For us non coding/html/java savvy folks, this kind of thing isn’t so obvious when starting out unfortunately.
If anyone could point me to showing the puzzle combination to do this I would be very grateful. Teapot and Robot have similar elements to what I need, I’m just too dim to relate them to my project sadly.
Basically, I have a short piece of text (basic viewing instructions for user in one sentence) within a div in another html file called overlay.html. The text div has a class name and id also named “overlay” to keep it simple like me
.I am trying to use the HTML puzzles to call this text within the div and show it in the centre of the screen during specific points in time. Presumably I need to use a simple html get div/id puzzle and then display it in a specific position with styling. I just cant seem to make any puzzle combo work :/
Is there a screen shot somewhere showing the puzzle combination I should use please with an explanation of what each puzzle entry corresponds to ideally?
I don’t want to assign to an annotation, because as I understand, that would be fixed in a 3d space and not independent for just screen display on top as an overlay.
Many thanks,
Jas
2020-11-16 at 12:23 pm #35368
Yuri KovelenovStaffHi,
you can first load the html file using the load data puzzle
https://www.soft8soft.com/docs/manual/en/puzzles/Advanced.html#load_dataThen you create a new HTML element (a DIV)
https://www.soft8soft.com/docs/manual/en/puzzles/HTML.html#add_HTML_element
…and position it using the set style puzzle
https://www.soft8soft.com/docs/manual/en/puzzles/HTML.html#set_style
Finally, you can inject the contents of the loaded html file into this DIV using this puzzle
https://www.soft8soft.com/docs/manual/en/puzzles/HTML.html#set_attribute
(select innerHTML in the dropdown)2020-11-16 at 12:53 pm #35372jaspixel
CustomerHi Yuri,
Ok great thanks, I’ll give it a go.
Was thinking of just setting visibility:hidden in CSS for the divs, then trying to show them with puzzles as is effectively what I did with my menu to stop it showing during the preloader.
I’ll check your method though as offers more control I imagine, many thanks.
Jas
