HMTL package?
Home Forums General Questions HMTL package?
  • #17250
    patrickbelt
    Hello. I’ve seen in other discussions that Verge3D does not have the same .HMTL export/package option as Blend4Web did. Is this a feature that we can expect from Verge3D someday? If not, do you have any suggestions for how I can build create a single .HTML file myself?
    I have explored using Electron, and was able to successfully create a stand-alone .EXE file of my project, however I cannot seem to find a way to create a .HTML file using it. I also did a little research on Cordova, and I can’t find a way to us it to create .HTML packaged files either. How did Blend4Web do this? Thank you! – Patrick
    patrick.c.belt@gmail.com
    #17258
    Sorry, we are not planning to implement that all-in HTML packaging feature, at least in the near future. It would require rather serious implementation effort and we cannot dedicate developers on it at the moment. :unsure:
    #23078
    patrickbelt
    Hi Yuri,
    I would like to revisit the above topic regarding the ability to publish Verge3D projects as a single HTML file. Is this possible yet? If not, will this feature ever be added to Verge3D?
    The reason I keep asking is because I would like to have the ability to embed interactive Verge3D scenes that I create directly into the eLearning presentations I develop using Adobe Captivate – without needing to link to an external website, or the need for an internet connection.
    Thank you,
    Patrick
    #23092
    There is no plans for this feature yet. As I can understand, Adobe Captivate produces a set of HTML/CSS/JS files just like Verge3D does. It looks like the recommended way of running this content is uploading to some web server first. See this discussion:
    https://community.adobe.com/t5/captivate/why-doesn-t-my-html-export-work-on-my-local-computer/td-p/9607061?page=1
    As such, you surely can embed Verge3D apps in your eLearning presentations, provided that they are launched from a web server (local or remote). If running from desktop is a must, you wrap your web app in a desktop application with Electron. See this tutorial:
    https://zjbcool.com/electron-app.html (in Chinese)
