High Memory Usage
Home Forums General Questions High Memory Usage
  • #9958
    JillR
    Hello,
    I’ve made a test case for a configurator and everything works as I want it to, but I’ve noticed that when I run my configurator Chrome’s memory usage skyrockets.
    All parts of my configurable object have a base material applied to them which then have a layer of details applied over them using masks. I use 3Ds Max so I do this by using a Mix node to mix my base material with a single colour using a black and white mask. I have 5 of these masks in my scene and they are all about 60 to 80 kB in size and a power of 2.
    When I just use the base material Chrome uses about 1.000 MB max but when I add the additional details it goes up to about 3.500 MB, which seems excessive.
    #9962
    Can you attach here an example file for us to check? thanks!
    #9969
    JillR
    I’ve sent the project via email.
    #9971
    Hi again,
    It appears you’re using very big images in your scene – I counted several 8k textures besides others. While their file size is moderate, they occupy a lot of memory when they are loaded.
    Checkout out this guide on how you can optimize your images: https://www.soft8soft.com/docs/manual/en/introduction/Workflow.html#Image_Formats_and_Resolution
    #9998
    JillR
    Hello,
    Thank you for the reply. I simply tried to use the assets as we have them and use in other software. I’ll try and see how I can best optimize everything.
