hiding object doesn’t work with html button revealed by hovering
Home Forums Puzzles hiding object doesn’t work with html button revealed by hovering
  • This topic has 21 replies, 2 voices, and was last updated 1 year ago by kdv.
Viewing 7 posts - 16 through 22 (of 22 total)
  • #69686
    alissa
    Thank you so much for your help! Everything is working now
    #69689
    Reduced the size of your visual_logic.xml from 3,5 Mb to 1,9 Mb :scratch: You are using too many repeating puzzles instead of using variables.
    #69717
    Why are you using FullHD images as backgrounds for buttons? :scratch:
    #69760
    alissa
    Sorry for answering just now. Thank you for reducing my file sending it to me! Could you tell me how I can incorporate it into my project because I am not experienced with coding.
    Also I did some changes since.
    I just published my site on webflow and the problem is that it takes to much space, so the paige automatically refreshes and also freezes sometimes. I know there are some things like the images to big and that’s why. I am going to change the image size of the buttons but is there something else I can do to fix it? But just have 2 more days left, because I have to hand it in for my bachelors.
    One more thing: The sky-sphere should not be draggable because I have set a constraint for it but when I drag over it on the edge of the screen I can move it out. Is there something I can do?
    #69761
    Download, unpack, replace visual_logic.xml in the app’s folder, run the Puzzles editor, resave puzzles.
    #69764
    alissa
    Okay thank you! But will it delete the changes I made since then?
    #69765
    Yes. Backup.
