Help! Table configurator size changing logic
Home Forums Puzzles Help! Table configurator size changing logic
  • #49309
    andrei pek
    Hi, I’m new to verge and I’m trying to make a table configurator logic for changing the dimensions of a table (attached image)
    In the UI there you can see I have 2 variation groups, height for legs and size of table, and I want to change the size of the table according to the user’s input, (small legs but large table or small size large legs and so on)
    I can’t figure out the logic on how to make this work.
    #49323
    if I understand you correctly, you can achieve this by morphing. You can create some UI slider for morphing by puzzles.
    Morphing in:
    Verge3D Developer
