HDR from BLENDER with Verge3d GLB exporter
Home Forums General Questions HDR from BLENDER with Verge3d GLB exporter
  • #56850
    filippobignami
    I have found trouble exporting the hdr file from Blender with the Glb format.
    If i try with the GLTF exporter(the one of Verge3d) all works well;
    if i try with the GLB formats(also the one of Verge3d), instead, gives me this error:
    v3d.js:1 v3d.RGBELoader Bad File Format: bad initial token
    As anyone know how to fix it ?
    in case this is not possible , how can I load directly an HDR file from verge3d?
    #56860
    Thanks for reporting, reproducing this issue on our side. Going to fix this in the next Verge3D update.
    X | FB | LinkedIn
    #63509
    cangunes
    Hey, I am using verge3d 2.13 version. I have encountered this error, what can I do? I want to export .glTF when i import bin and glTF file, then return this error. I can’t change version. So, Is there a alternative?
    • This reply was modified 1 year, 11 months ago by cangunes.
    #63517
    In your case just remove the HDR texture from the world material.
    #63522
    cangunes
    Thank you
